As shown the current shunt, operational amplifier, and microcontroller all share a "common" which is the negative power input to the microcontroller. Configure a standard single supply operational amplifier as an inverting amplifier, and the negative value from the current shunt will become a positive value referenced to the microcontroller's negative power input which is a common configuration for 4 to 20 milliamp sensors to measure their own output current.
