Author Topic: Do inductors sing in old age?  (Read 1933 times)
Offline NivagSwerdnaTopic starter
« on: May 12, 2019, 02:11:51 pm »
I built a nixie clock a few years ago and I have noticed it has got quite loud... at first I thought it was the tubes singing and a multiplex effect but I am now pretty sure it is the inductor in the HV power supply.
The inductor is a 220uH CoilCraft job.
The clock has been on continously for around 2 years... do inductors wear out?  Sing in old age?
Offline BravoV
  • +++ ATH1
Re: Do inductors sing in old age?
« Reply #1 on: May 12, 2019, 02:41:20 pm »
Thermal cycle eventually will make something loose.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: May 12, 2019, 03:57:27 pm »
More often it's always singing, and either you never noticed it (too high frequency? Environment changed to make it more audible?), or the singing frequency changed.
Adhesives can conceivably fatigue loose but I wouldn't think this very common, unless it's been exposed to temperatures so hot that magic smoke could be smelled.
The frequency can change due to marginal compensation and aging of electrolytics or the like.  Electrolytic capacitors are the component most prone to aging.
Shall I guess it's the usual shitty Nixie supply circuit, no protection or nothing?
Seven Transistor Labs, LLC
Online Berni
  • Country: si
« Reply #3 on: May 12, 2019, 07:04:51 pm »
It could certainly be something getting loose due to thermal cycling.
Often a reason for switching supplies starting to make noises is the electrolytic caps gradually degrading in performance. This makes for more ripple on the rails and this ripple can cause ceramic capacitors to make audible noise trough the piezoelectric effect.
The trick i use for locating the noisy component is to press tweezers on components one by one until i find one where the sound changes when poked. This mostly works by the tweezers picking up the vibrations and vibrating along it to make the sound louder.
Offline Benta
« Reply #4 on: May 12, 2019, 07:39:05 pm »
Be happy that it sings! Most inductors just hum, and it's a major task to teach them the lyrics!   :-DD
Sorry, couldn't resist...
The following users thanked this post: Berni, exe, Ian.M, NivagSwerdna
Online MarkF
« Reply #5 on: May 12, 2019, 07:44:28 pm »
It needs some backup singers...    :clap:
Check the Fluke 98 song in this other thread  https://www.eevblog.com/forum/beginners/custom-firmware-for-old-oscilloscope-(ideas)/msg2405760/#msg2405760
Offline Brumby
« Reply #6 on: May 13, 2019, 12:32:52 am »
I could say "try harder" .... but it made me smile.   :D
Online Berni
  • Country: si
« Reply #7 on: May 13, 2019, 04:15:32 am »
Well the music industry is pretty saturated these days anyway. :D
Offline innkeeper
« Reply #8 on: May 13, 2019, 04:39:23 am »
it's trying to get inducted into the rock and roll hall of fame.
and to think it knows only 1 chord.
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline Brumby
« Reply #9 on: May 13, 2019, 05:54:25 am »
 :palm:  Please tell me that's all.
..... Please.
* Thinks: You hypocrite ... you're still smiling! *
Offline CJay
« Reply #10 on: May 13, 2019, 08:52:24 am »
Yes, they can do, I've also heard inductors/transformers 'singing' because of other components going faulty (electrolytics usually), changing those bits silenced the inductors
« Reply #11 on: May 13, 2019, 09:28:01 am »
I attached the clock to a lab power supply and gave it 12v and then adjusted the voltage down. Interestingly at about 11v it is considerably quieter and then gets louder again towards 9v. I also notice that it is quieter when not under load.
I really don't remember it being this noisy and putting my ear close I can perceive what might be described as fizzing or at a stretch crackling.
Perhaps I should preemptively replace the input electrolytic? (Which is a PITA since it is SMD flavour)
Just checked my schematic and I'm pretty sure I ended up with...
"EEEFTH101XAP -  SMD Aluminium Electrolytic Capacitor, Radial Can - SMD, 100 µF, 50 V, 0.34 ohm, FT Series" on the input side.  That looks like a good choice... not sure I have any spares.
« Last Edit: May 13, 2019, 11:02:50 am by NivagSwerdna »
Offline soldar
« Reply #12 on: May 13, 2019, 11:07:03 am »
I had an old hard disk that would sing the Travi-ATA.
The newer ones do the Travi-SATA
The following users thanked this post: NivagSwerdna
Offline CJay
« Reply #13 on: May 13, 2019, 11:19:11 am »
Could be input or output, could be both, could be neither and it could be a loose winding on the inductor as well.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #14 on: May 13, 2019, 11:28:58 am »
yes they do sing old or new... if you have more time to kill you can build something useless and have a life by getting 50K likes, and possibly participate in america got talent or hope george lucas will hire you and then have some stories to tell your grand children.
Offline GreyWoolfe
  • NW0LF
« Reply #15 on: May 13, 2019, 11:38:33 am »
Here we are, the beginning of the week, Punday. :palm:
