Author Topic: substitute for 2Ж2М tube  (Read 891 times)
Offline ELS122Topic starter
« on: February 02, 2020, 01:38:23 am »
I want to know what is the equvalent of the  2Ж2М pentode
I can't even find a datasheet for it.
Tac Eht Xilef
  • Guest
Re: substitute for 2Ж2М tube
« Reply #1 on: February 02, 2020, 04:27:36 am »
There isn't a direct replacement for the 2Ж2М/2j2M/2Zh2M. The 2K2M is close, but it's a soft cut-off vs sharp cut-off. The European KF3 & KF8 can sub for the 2K2M, with modifications.
Some data for the soviet tubes can be found here - and here :-DD
« Reply #2 on: February 02, 2020, 04:39:33 am »
dude, that's confidential information you're giving :-DD
and I also have looked at the datasheet on gstube, I don't know why I said I didn't  :-//
well, thanks anyway.
I probably will not use these than in my amp cause gstube doesn't even sell them. if they don't sell it then I'm probably never going to find a source for them.
« Last Edit: February 02, 2020, 04:42:12 am by ELS122 »
Tac Eht Xilef
  • Guest
« Reply #3 on: February 02, 2020, 05:22:16 am »
If you didn't have any and knew you couldn't get them … why fucking ask? |O :palm:
Another one for the filter…
« Reply #4 on: February 02, 2020, 05:39:38 am »
no, I was thinking of finding one amp that has a pair of these tubes but if they are not so good, and if I can't get new ones.
wait... yeah it seems dumb actually.
well at least I got some info for those tubes :-+
