I'm looking through the datasheet for the
OPA691, and I'm a bit lost on how to select and adjust optimal parameters for an inverting circuit. I was wondering if I could get some feedback on my thought process.
I'm more or less trying to follow the example shown in Figure 9, expanding it out to multiple inputs and keep a gain of -2. If done correctly, I feel that I should be able to get a pretty high bandwidth of ~200 MHz. To help illustrate things, I've attached a picture which is more or less the same as Figure 9. The only thing to note is that when I expand it to accommodate N inputs, the box on the left is replicated in parallel to account for multiple inputs.
So, to start off, the gain of each input, A, is written as [-R
FB/R
G]. To match the source impedance, [R
G||R
M] should be close to 50-ohms. Now, the noise gain (NG) is written as [1+ R
FB/(((R
G+{R
M || 50}))/N)], where the denominator is the sum of R
G and the parallel combo of the source impedance and R
M. N is the number of inputs in the inverting summer. Once you figure out the noise gain, you can use the chart in Figure 8 to approximate a feedback resistor value; from there, you follow the equation shown in Equation 4 to get a sum close to 472 for optimization.
From all this, unless my reasoning is wrong, most of the terms are dependent on NG and R
FB for their calculations. However, you can't solve for NG without picking a value for R
FB. However, at the end, R
FB is determined by NG. This feels slightly circular. How would you approach this design. Do you start by picking a feedback resistor without taking into account impedance matching? From there, using this value, you then account for impedance matching? Sorry if this sounds confusing, but I'm just kind of lost.
