Author Topic: How does an antenna work?  (Read 22718 times)
Offline WartexTopic starter
    • http://headsplosive.com
« on: May 22, 2011, 12:22:16 am »
I always wondered, what is the fundamental principle of operation? I get the whole "AC causes electron movement which causes RF radiation", the problem is, every forum I've been to, the last, and always unanswered question is "How do you get current flowing" if antenna is *not in a circuit*, at least galvanically?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: How does an antenna work?
« Reply #1 on: May 22, 2011, 12:41:51 am »
you need a physicist forum for this. i dont have an exact answer, just an imagination :P that electron movement is like ripple of water. in the antenna, its like a dead end tunnel where the ripple try to go out but then got reflected back. there will be no net electron movement, but this jiggling like motion, with proper tunnel/antenna length will create resonance and amplify the rippling hence electromagnetic force/wave. i imagine potential also is like pressure thats try to push and pull electrons in the antenna. maybe thats just my science fiction imagination.
Offline Tony R
« Reply #2 on: May 22, 2011, 12:43:55 am »
I'm not an expert in this area but I wish to point out that if you increase the voltage on an antenna, you add charge to it, the charge will want to even out thus they are moving, a moving charge is a current.
I do know that radio waves are due to accelerating electrons. acceleration means motion so they have to be moving, and the above answer is the only way i know of that you can get movement of electrons.
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,  IEEE Student Member
Offline Trigger
« Reply #3 on: May 22, 2011, 12:45:26 am »
Too much to type so...
http://youtu.be/7Sgtq-ncZAE
Offline johnmx
  • Country: pt
« Reply #4 on: May 22, 2011, 12:46:36 am »
What do you mean with: “antenna is *not in a circuit*, at least galvanically”? Between transmitter and receiver?
If you understand what causes RF radiation than you know the answer of your question.
Best regards,
johnmx
  • Country: my
« Reply #5 on: May 22, 2011, 02:44:44 am »
with the genius of its mathematical formulation, its still dont answer the common sense stuff, such as where the standing wave comes from? why the current moving at one direction and then another one at the opposite direction at certain points in the antenna? and it only explain dipole type of antenna, how about monopole?
edit: ok, moving electrons will create electromagnetic field (radio), thats noted.
« Last Edit: May 22, 2011, 02:50:15 am by Mechatrommer »
Online vk6zgo
« Reply #6 on: May 22, 2011, 04:03:40 am »
Wrong forum,try QRZ.com,but before you sign up & ask questions,browse through the Antenna Forum section.
You might find your answer there.
Also,Google for W8JI--Tom is a very knowledgable person,& his writings on Antennas are always worth reading.
See if you can find the ARRL handbook, the RSGB Manual,or ARRL Antenna Book at your library.
Although these books are for Amateur Radio Operators,they contain a lot of excellent information.
VK6ZGO
Offline the_raptor
« Reply #7 on: May 22, 2011, 04:15:56 am »
RF radiation is a series of alternating electrical and magnetic fields. An electrical field generates a perpendicular magnetic field and then collapses, the magnetic field generates a perpendicular electrical field and then collapses, and so on. Eventually one of those magnetic fields is generated close enough to an antenna that the new electrical field is generated ON (RF travels on the skin of a conductor) the antenna and thus can be measured to pull signal out. Making the antenna an antenna a specific portion of a wavelength (pretty much no one uses full wavelength antennas, in amateur use 1/4 wavelength is common) gives you selectivity because the fields of that frequency generated on and around the antenna won't cancel each other out as much.
RF is NOT AC in that you can not apply basic AC circuit theory and come out with an understanding of RF. Which I presume is the OP's problem. For RF you need to understand AC outside of wires and in the world of electrical and magnetic fields.
P.S. Mechatrommer. There is no such thing as a real monopole antenna. All "monopole" antennas are just dipoles which use a "ground plane" as the one half of the antenna. Which is why you can improve the send/receive ability of handheld transceivers by clipping on an extra bit of wire instead of relying on the users body being the ground plane. For non-mobile "monopole" antennas more copper is buried for the ground plane than is sticking up in the air.
« Reply #8 on: May 22, 2011, 05:08:48 am »
Hi Raptor, thanks for the explanation. I have a fairly good understanding of physics and I see the direction you are pointing me at. I will state what I understand and maybe you can clarify where I'm wrong.
So, here goes:
When there is a difference of potential between two points, i.e. variance in quantity of free electrons in the atomic structure and a conductor is applied between those two points, an electric field is propagated thru the conductor with a speed fractional to "c" (299997 Km/s), say for a straight copper conductor we will assume 0.75*c. Once the field is propagated, it interacts with electrons' own fields and repels them in the direction of propagation. The spin of moving electrons creates a magnetic field oriented perpendicular to the conductor.
With AC, we have same process plus inductance and capacitance of the wire. I noticed in some radio designs the transmitter would have a transformer at the end where the circuit is driving the primary and the secondary has one end earthed and the other going to the antenna. This to me looks like a huge LC circuit where the air between antenna and earth is a huge air capacitor, and I can imagine the electrons moving from antenna to earth and back, creating an EM field lines that start at the tip of the antenna and end at the grounding point, propagating into infinity.
The problem is that antenna would not produce any radiation if no energy is dissipated into it, so the currents must be induced in the antenna. At a minimum you need circular currents as in permanent magnets, and my understanding is that currents in the antenna are longitudinal and not circular. Ok, I'm fine with electron oscillations and zero net current, but there must be instantaneous currents - how the hell are they produced for example in solid-state transmitters where you have a 1 pin of a chip terminated with a copper trace? and I want too see a "picture" of EMF produced by a simple "stick" antenna.
Offline the_raptor
« Reply #9 on: May 22, 2011, 05:49:48 am »
Wartex, I am only just beginning my exploration of (amateur) radio so I don't know if I can answer to the depth you want.
It is my understanding that in a standard dipole even though the two arms of the antenna aren't electrically connected at their ends they are coupled by the EM field, which is what the "standing wave" in an antenna is. You don't have energy magically pumped into one element, the whole thing forms a RF circuit with part of the power that goes into the first element being returned  through the second (this is called the "Standing Wave Ratio", and the basic goal of antenna design is to get this close to 1:1).
To rephrase it slightly, the electrical current in the dipole elements and transmission line is only part of the RF circuit, the circuit is completed by the RF wave between the two elements of the antenna.
Also if the AC being feed into the dipole isn't of the correct frequency for the length of the antenna more and more current is returned down the feedline instead of "jumping off" into space as RF radiation. It is an amateur radio maxim that the antenna is more important than the transmitter. eg my main transmitter is rated at 10 watts, with the antenna I have set-up currently I doubt it puts out 1 watt of that as radiation.
The radiation pattern for a "perfect dipole" in "free space" would be an ovoid down the length of the dipole, with the greatest radiation going off the beam of the antenna and with the ends being nulls. However it quickly gets a hell of a lot more complicated with an antenna near the earth operating outside of the exact wavelength of the antenna, even ignoring parasitic elements etc.
Antennas are probably the most complicated AC subject that exists. Personally I only have a vague notion of how they work (I need the ARRL antenna theory book), and I think to have a good understanding would take several years of full time study.
  • Country: my
« Reply #10 on: May 22, 2011, 06:09:26 am »
...more and more current is returned down the feedline instead of "jumping off" into space as RF radiation...
this is even more confusing! how can a current jump off space? afaik current is opposite direction of electrons, how can an electron jumps in and out off space from an antenna?
Online vk6zgo
« Reply #11 on: May 22, 2011, 06:18:57 am »
A bit misleading,in that it  unintentionally perpetuates the common myth that there is something "magic" about RF frequencies.
In fact,a 1/2 wavelength dipole antenna at 50Hz will radiate just as effectively as one at 50MHz.
At such extremely low frequencies,antennas are impractically long,so this part of the spectrum is not used for this purpose.
Frequencies just above the audio region are quite commonly used,however,& some "hams" are at present transmitting
on 8kHz--inside the audio region, using a special experimental permit.
VK6ZGO
« Last Edit: May 22, 2011, 06:21:46 am by vk6zgo »
  • Country: my
« Reply #12 on: May 22, 2011, 06:32:32 am »
i dont see it answer the question vk6. we know the lower the freq, the longer the antenna, and all that audio band signal. we are talking antenna in general, no matter what frequency it is. but for simplicity, the freq should be high enough (practically), to avoid audio band and gigantic antenna size, it is also known, freq as low as 10Hz can be radiated, but surely that will be off topic.
Offline the_raptor
« Reply #13 on: May 22, 2011, 06:46:18 am »
I was talking about the difference between AC in the world of wires and AC involving EM fields. Basic AC circuit theory ignores the fact that current in a wire generates a field which then generates a current in other wires (unless specifically talking about transformers and the like). It is like physicists using round cows and a frictionless surface to describe momentum.
This is mainly because until the advent of high speed digital circuits you could pretty safely ignore RF because wiring was unlikely to be long enough to function as an efficient transmitter at the frequency of operation of the circuit. These days that isn't true and so the RF spectrum is being drowned out by devices that have no business transmitting.
I should have probably used "radio" instead of "RF". I am used to thinking about "RF energy", but not necessarily meaning "radio frequency energy".
  • Country: my
« Reply #14 on: May 22, 2011, 06:56:42 am »
we can google all we like about radio, but try to concentrate on the above mysterious question. i think the OP meant by saying "not in the circuit" is the antenna is not connected to the classic 2 port device, such as +ve to -ve wire or network. i think this is deeper than a ham can comprehend. this is just as mysterious to me as i pointed out the monopole. ok there is another pole at the base, but how it does it work up to the antenna tip high up there? its like a magic remote telekinesis. and if you chop some cm of the monopole, then the radio performance will be affected.
« Last Edit: May 22, 2011, 07:03:13 am by Mechatrommer »
Offline the_raptor
« Reply #15 on: May 22, 2011, 06:57:56 am »
Sorry, could have been more clear. It is the energy that is "jumping off" into space. I intentionally used a fuzzy description because I am not sure myself the exact mechanism that translates a EM field around a wire into an EM wave propagating through space. As I was talking about before, just running a current into an antenna isn't enough for something to be an efficient antenna. The wave length of the current has to relate to the length of the antenna or else the energy will just flow back down the other side of the transmission line instead of being radiated (and radio people worry about Standing Wave Ratio for this reason, most amateur gear starts to cook once SWR exceeds 1:1.5).
P.S. Also AFAIK your description of current is wrong as well. Although current is often described as the movement of electrons IIRC it is more energy transmitted via the movement of electrons. The pipe analogy of electricity where you are sticking electrons in one end of a pipe and they come out the other is a "round cow" analogy.
Offline the_raptor
« Reply #16 on: May 22, 2011, 07:07:55 am »
I thought that was what I answered?  :'(
There is an EM wave/field between the two sides of a dipole that completes the circuit.
  • Country: my
« Reply #17 on: May 22, 2011, 07:13:42 am »
no worry mate, i'm also as eager as the op about this mystery. i think there's misunderstanding between "current" and "electromagnetic wave". i believe they are both different.
Offline Bored@Work
« Reply #18 on: May 22, 2011, 08:00:22 am »
The honest answer is, mankind doesn't really know how an antenna works. We use models of different granularity to describe effects we have observed in nature. Some of these models are very good, so good that one can predict nature's behavior from the model.
But the more you drill down, the more complicate and abstract it becomes and in the end still no one can tell you what it really is. Others here have argued with field theory. Maxwell's equations should come up here, too. Good stuff. And where do the fields come from, what is their fundamental principle of operation? One could now dig out more theories. And start to ask physicist about even more and more details and fundamentals. Any honest physicist will at some point tell you
"This [insert incredibly big ball of math here] is current the best theory we have. It is a very tricky, abstract and complicated model. It takes years to learn it. Not many people in the world understand the model. It can explain a lot and we have some measurements showing the model might be correct. We are missing other measurements. And there are some who claim they have conflicting measurements. And we scratch our head about some aspects. No, we don't know the real fundamental principles of how all this works. Every time we think we have it, something new comes up."
In practice this means that you have to take a model you can still handle, i.e. one you math is good enough for, and make the best out from applying that model. And treat the rest as "well, that's the way it is".
Simple models for antennas are rules of thumbs. E.g. describing certain antenna types with a few simple formulas, because people figured out in the past that this is good enough for many practical purposes. Often by experiment.
« Reply #19 on: May 22, 2011, 05:08:55 pm »
Haha -  so far, no answer.
My point is that to generate EM field you need current flowing, be it straight or oscillating, period. It's just physics.
We know that electric field is propagated to the end of the wire when it's connected to the voltage source ON ONE END. The current starts flowing and magnetic field is created when the other end is connected, unless E field is strong enough to push electrons over the gap between the end of the wire and the other voltage source terminal.
So, there must be some magic happening when direction of *electric* field is changed. I guess the change itself created currents.
Offline Zero999
  • 0999
« Reply #20 on: May 22, 2011, 06:06:04 pm »
The question has been answered.
Let's go back to the original question:
The answer is the antenna is a circuit galvanically, not at DC but at the frequency of operation. In a dipole the current flow in the lower half of the antenna is 180o out of phase with the top.
In a monopole the ground plane acts like a capacitor. which sources and sinks the current because it has self-capacitance, see link to Wikipedia below.
http://en.wikipedia.org/wiki/Capacitance#Self-capacitance
This means that at high frequencies, a circuit can flow between two objects which are not electrically in contact with each other and are too far apart for them to have mutual capacitance. You can see this by holding a metal object attached to a non-conductive plastic pols near a Tesla coil and a spark will leap towards it.
I hope you can see that a loop antenna is a circuit not note that at DC its impedance is near 0 Ohms, at the desired frequency it's within the design limits, from memory typically 300 Ohm for a standard loop. A dipole antenna has a near infinite impedance at DC but is 75 Ohms at the resonant frequency.
  • Country: my
« Reply #21 on: May 22, 2011, 06:21:10 pm »
so, is that means, dipole and monopole are capacitor? and loop antenna is an inductor?
Offline Zero999
  • 0999
« Reply #22 on: May 22, 2011, 06:23:31 pm »
That's true at low frequencies.
At the resonant frequency, they're purely resistive.
Above the resonant frequency a dipole is inductive and a loop is capacitive.
The difference is a dipole responds to the E-field and a loop responds to the L-field.
  • Country: my
« Reply #23 on: May 22, 2011, 06:57:38 pm »
ok, googling leds me back to maxwell/faraday equation, looking at the symbols, i better surrender rather than having my days ruined. i will just cut or add my antenna when needed :P thats it!
« Reply #24 on: May 23, 2011, 02:41:57 am »
Hero999, are you stating that antenna has currents in it to create EM field because each wire of dipole is capacitively coupled to the other wire?
What about early satellites? They are not grounded in any way, in near vacuum, monopole stick antennas.
Answer me this: How do you generate non-zero-net current in a single wire?
What type of field does an antenna produce?
So far all the explanations are WHY antennas work, but not how.
Online vk6zgo
« Reply #25 on: May 23, 2011, 05:13:01 am »
I repeat my original advice.Look it up in one of books I mentioned,Google for it.
Stay away from highly mathematical texts till you get a feel for things.
Antennas do work,& have been working for many years,so I also suggest you re-read BoredAtWork's answer above,he is giving you good advice.
I wrote a huge screed with some (I thought) pertinent information,then accidentally lost it.  :-[( I hate touchpads!!!)
VK6ZGO
Offline insurgent
« Reply #26 on: May 23, 2011, 03:44:19 pm »
Here's a PDF that explains without math, how dipole and monopole antennae work. Apparently the monopole is still two parts, just the second part is a "reference plane" which doesn't have to be ground.
http://www.hottconsultants.com/pdf_files/dipoles-1.pdf
« Last Edit: May 23, 2011, 07:30:32 pm by insurgent »
Offline Zero999
  • 0999
« Reply #27 on: May 23, 2011, 04:49:06 pm »
It's more about self capacitance than mutual capacitance which only exists between two objects.
Because the satellite has self capacitance like any large metal object as I explained above.
You need to understand how self capacitance works before gong further. An single conductive object millions of miles away from any other object has self capacitance because electrons can be removed and added to it. This is how electrostatics work and the same principles are important at high frequencies.
The "reference plane" just has to have enough self capacitance for its impedance to be low compared to the antenna at the frequency of operation.
Large, low frequency aerials just use the earth as a reference because it has a very large self capacitance. At higher frequencies much smaller metal objects can be used.
« Reply #28 on: May 23, 2011, 05:09:41 pm »
VK6ZGO
You can always hit CTRL-Z if you selected and deleted a huge chunk of text. Also, http://code.google.com/p/touchfreeze/
Offline jahonen
« Reply #29 on: May 23, 2011, 05:39:11 pm »
John D. Kraus (RIP) defines the antenna in his "Antennas for all applications" book as
A radio antenna may be defined as the structure associated with the region of transition between guided wave and a free-space wave, or vice versa. Antennas convert electrons to photons or vice versa. Regardless of antenna type, all involve the same basic principle that radiation is produced by accelerated (or decelerated) charge. The basic equation of radiation may be expressed simply as di/dt*l=Q*d2v/dt2. Thus, time-changing current radiates and accelerated charge radiates.
Thus, I'm not entirely sure if the capacitance approach is intuitive. It seems that current is the fundamental thing which causes radiation from suitable structure.
For example, a slot antenna has almost identical radiation pattern than dipole, but has the electric and magnetic field components interchanged. Slot antenna can be constructed from a metal sheet by making a slot in it which has appropriate length. Obviously, it is a bit hard to think about capacitance over the slot (I'm not even sure that it is required to produce radiation). And how about a horn antenna, which is a suitably formed waveguide?
Regards,
Janne
Offline Zero999
  • 0999
« Reply #30 on: May 23, 2011, 06:31:56 pm »
I think what he's failing to understand is how the current flows in a monopole when there's only one wire connected to it, the other is connected to nothing so it's apparently open circuit. He needs to understand the electrons are being moved back and fourth between the ground plane and the antenna.
Of course self-capacitance is not important for all types of antennas.
« Reply #31 on: May 23, 2011, 10:02:53 pm »
I understand that very well, you haven't read my first posts carefully. My question is this: A satellite in space has N number of free electrons in it, PERIOD (assume it has NO solar panel and just a battery).
Somehow the transmitter circuit will displace a certain amount X of electrons from the body of the satellite (dipole lead #1 aka ground plane) to the whip antenna (dipole lead #2). Electrons will exhibit wave nature and fly off the antenna as photons. So here we have the energy conversion from matter to wave. Correct? Correct.
The question is: HOW do you displace the electrons from ground plane to the antenna? For you to move electrons you need a difference of potential between the antenna and the ground plane. According to your explanation, every transmitter is a static pump and nothing more.
Offline Time
« Reply #32 on: May 23, 2011, 10:56:33 pm »
The answer is not exactly straight forward for an online forum but if you study maxwell's equations you can see how radiation is produced from accelerating and decelerating charge.  Maxwell's equations are a set of partial differential equations which describe electromagnetics in its entirety.  The changing electric field combined with the changing magnetic field produces radiation in a pattern dictated by the antenna shape.  Its not useful to think of antenna radiation as photonic in nature because the wavelength is so large.
The electrons themselves do not fly off the antenna.  They simply radiate energy when they experience acceleration and deceleration.  This can effectively be quantified as a resistive loss but the bi-product is not heat.  It is radiation.
Current flows but the electrons only move back and forth over a small distance, they don't actually flow around and around the ground and antenna.  They might move only a few millimeters or centimeters.
-Time
« Reply #33 on: May 24, 2011, 05:27:41 am »
How do you induce current in a wire connected at one end only, if it was stated that antenna is NOT capacitively coupled with the ground plane?
Offline jahonen
« Reply #34 on: May 24, 2011, 06:23:20 am »
Wire (or any antenna) "sees" the impedance of the vacuum, about 377 ohms, resistive, thus the current in the antenna. It is the antennas task to match the feedline impedance to the impedance of the vacuum (or whatever it is). I personally think that the vacuum impedance is a difficult concept to grasp intuitively, since 377 ohms is pretty low value for something that has nothing in it :) Corresponding impedance is about the same for air also.
Regards,
Janne
Offline johnmx
  • Country: pt
« Reply #35 on: May 24, 2011, 09:11:05 am »
That antenna is only an open-circuit for DC, not for RF!
Best regards,
johnmx
  • Country: my
« Reply #36 on: May 24, 2011, 09:37:42 am »
if you think electrons movement is similar to water ripple or string or slinky spring, things will be much easier. but thats just me.
« Reply #37 on: May 24, 2011, 11:52:01 am »
I know. Please explain, on a field level, how that current is induced. Also avoid RF as a magic word because it creates circular logic: "current is induced due to RF, RF is what induces current"
« Reply #38 on: May 24, 2011, 12:06:18 pm »
I think of electrons as orbital clouds experiencing particle-wave duality under certain conditions. Simplifying it the wrong way to get the explanation across is not a scientific solution. Oscillating electrons radiate NOTHING unless they jump energy levels and produce/consume a photon. Also, after reading some physics whitepapers I confirmed my knowledge that there is nothing magic about RF radiation and IT IS photonic in nature, and all equations apply equally to visible light and RF radiation.
« Reply #39 on: May 24, 2011, 12:10:43 pm »
Regards,
Janne
Good explanation.
Offline Zero999
  • 0999
« Reply #40 on: May 24, 2011, 05:13:54 pm »
I think the quote below answers that pretty well.
A static pump is a good analogy for how the oscillator pumps electrons to and from the ground plane in and out of the antenna, although static probably isn't the right word as the electrons are always moving.
Because the ground plane has self capacitance which is not reliant on being coupled to the antenna or anything else.
If you run a Van de Graaff generator until it charges to say 100kV, stand on a non-conductive plastic box and touch the charge dome, a spark will leap towards your finger and you'll receive a shock.
Why can thsi happen you're not grounded?
The answer is the electrons flow from the charged dome (assuming its negatively charged) into your body until the charged is balance.
Where do all those electrons come from?
The earth. The Van de Graaff generator pumps electrons from the earth into the metal dome making it negatively charged. If you now touch the earth, you'll receive another shock as the electrons flow from your body back into the earth.
If you replaced the Van de Graaff generator with a high frequency AC source such as a Tesla coil, a sustained arc will form between you and the dome.
Why? You're not earthed, as you're standing on a plastic box.
The Tesla coil pumps electrons back and forth between you and the earth at a high frequency so the charges never balance.
The same thing happens with a transmitter, antenna and the ground plane, it just shifts electrons between the antenna and the ground plane, no electrons whiz off into space. The electrons don't get converted to radiation. Energy is required to overcome the resistance to moving the elections back and fourth which is mostly converted to radiation.
Offline Time
« Reply #41 on: May 24, 2011, 05:37:43 pm »
If you excite a single wire with a step type voltage the voltage is not going to appear through the whole conductor instantaneously.  It will take time to propagate down the length of the antenna.  Do this quickly and you have rapidly fluctuating charge ditributions thus producing radiation.  It doesn't matter what the impedance of the of the environment is, that just dictates how well this radiation couples into it.  You need to read about electromagnetic boundary conditions and other EM theory if you don't know the basics.
If you want to understand fundamental antenna theory you need to goto school and study electromagnetics and maxwell's equations.  Everything that an EE does is just watered down Maxwell's equations with assumptions thrown in. You certainly don't need to know the ins and outs of EM to be a good engineer but if you want to really grasp the fundamental physics there is no other choice.  When you start getting into the raw fundamentals of something like this EM theory becomes unavoidable.  No answer on here will ever be thorough.  Its simply going to be one persons conceptualization of the phenomenon vs. anothers.  To truely understand you have to view it in its elegant mathematical beauty and let your mind manifest its own concepts for what is going on.
-Time
