Author Topic: Weird backplane pattern  (Read 1112 times)
Offline jassuncao
« on: April 17, 2014, 09:10:50 am »
Hello all,
While I was tidying  up my workshop I found an backplane PCB from an old computer  with the following pattern (sorry for the crappy photo)
I assume these are ground guards to avoid crosstalk but it's the first time I saw this kind of pattern in a motherboard. Is my guess correct?
Thank you in advance.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Weird backplane pattern
« Reply #1 on: April 17, 2014, 09:17:06 am »
can I hazard a guess that this is on the back of an ATA port ? 80 pin ata ports go up to 133 MB/s rather than the 33mB/s on the 40 pin ports simply because every other wire is a ground and avoids cross talk like you say.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline jassuncao
« Reply #2 on: April 17, 2014, 10:42:15 am »
This is not an ATA port. From the type of connectors I assume it's a ISA or MCA  backplane from a late eighties server. I guess the designer made an extra effort to minimize cross talk in a <20MHz bus
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 17, 2014, 11:45:09 pm »
Yeah, reduces electrostatic coupling a little.  Wouldn't be great for rise times in the < 2ns range, but would be fine for anything CMOS/TTL back in the '90s or earlier.
Seven Transistor Labs, LLC
