Author Topic: How does noise Vrms and affect measurable peak-to-peak voltages of sine waves  (Read 2264 times)
Offline ddr_controllerTopic starter
I am having trouble understanding how noise affects the signals you can measure.
For example, imagine the real signal I want to measure of a sinewave with a peak-to-peak amplitude of 5uV.
This signal goes through a resistor before being amplified by an ideal amplifier. I don't understand the meaning or how to use the $V_{rms}$ that has $V/\sqrt(Hz)$, how do I calculate the bandwidth? What does V_rms have to do with the 5uV peak-to-peak of the sine wave?
My question is whether due to resistor noise, I will be able to measure the signal.
Offline BillyO
We don't have enough information to provide a meaningful answer about bandwidth.
1) The way the circuit is drawn, it looks like it will ideally have an infinite bandwidth.
2) The noise in the resistor would be reflected in the current through it.  If the source impedance was very low or 0, the noise through the resistor would not be a factor.
3) We know nothing of the resistor.  What's it made of and how is it made.  What are it's noise characteristics?
4) If the circuit is not ideal, what are the bandwidth limiting aspects?  Stray capacitance?  Inductance? The op-amp?
Now, as to you other question Vrms of a pure sine wave is Vp-p / 21/2:
Vrms = Vp-p/21/2   or   Vrms = Vp-p/1.4142   or   Vrms = 0.7071 * Vp-p
This relationship is only true of a ideal pure sine wave though.
Offline David Hess
  • DavidH
The conversion between Vrms and V/Sqrt(Hz) is:
Vrms = Sqrt(bandwidth Hz) * V/Sqrt(Hz)
And the peak-to-peak value is roughly 5 or 6 times the RMS value.
So working backwards, 5uVpp is about 1uVrms, and then to find the bandwidth, if the input referred noise is 5nV/Sqrt(Hz), which is typical for a low noise operational amplifier, then the bandwidth where noise is equal to the signal is 40 kHz.  If the noise was higher, then the bandwidth would have to be reduced, and of course in practice the noise must be lower than the signal.
That input referred noise could be from any source, and does not account for excess noise like flicker noise.  As shown, it is not possible to determine the noise contribution from the resistor because the source impedance is not known.
Offline BillyO
We know neither the bandwidth nor the frequency.  Or are you just giving a random example?
Offline TimFox
In general, when you add two signals that are uncorrelated, such as your sine wave and the random noise voltage, the rms voltages add "in quadrature".
That is, Vtot rms2 = V1 rms2 + V2 rms2.
As discussed above, you need to specify the bandwidth to get a finite answer for the rms noise voltage:  this is covered in textbooks that discuss noise.
Offline David Hess
  • DavidH
I gave an example with values that would be typical for a similar application.
With realistic parts, dealing with a 5 microvolt peak-to-peak signal will limit bandwidth to 10s of kilohertz at most.  DC accuracy would limit it even further.
« Last Edit: February 02, 2023, 08:06:44 pm by David Hess »
The following users thanked this post: BillyO
