Author Topic: Soldering iron for service work  (Read 4404 times)
Offline PetrosATopic starter
« on: October 29, 2010, 02:24:14 am »
One of the things I've been putting off for some time is getting a soldering iron for my truck. Locally, I can only find really cheap crap from Weller and I'd rather not go that route. I don't need an iron often, but when I do I'd like something decent with a tip that's not held in with a crappy little screw, I want it to have enough heat for even large joints and I want it to heat up relatively fast.
Some things that are confusing for me though is when looking at the higher end irons, I'm not sure what just plugs in and what needs a control unit (station type), what temp or wattage is going to be most useful, should I maybe be looking at something like the Hakko 980-V12 or /P? I know that the cheapie iron I have at home doesn't get hot enough for non-Pb solder - I couldn't fix a joint on my UPS because of that, so the dual temp feature of that Hakko seems sensible.
Does anyone have any recommendations or ideas I should look into?
Thanks
I miss my home I miss my porch, porch
Offline gonnafail
Re: Soldering iron for service work
« Reply #1 on: October 29, 2010, 02:50:18 am »
I have this:
http://www.amazon.com/Weller-WST2-Pyropen-Cordless-Soldering/dp/B000ICGMPW/ref=sr_1_9?ie=UTF8&s=hi&qid=1288320005&sr=1-9
It is a small portable butane powered iron. It is a handy little portable iron, great for doing wiring on the car or similar where you are in an awkward spot and don't want the cord in the way. You have rough temperature control by turning the sleeve on it which controls the amount of gas. I have never and would never use it on electronics though. I am just suggesting this as you say you want it for your truck where I am guessing you wont always have access to power. One thing with it is it can be annoying to light at times, I have seen that they have slightly larger self igniting irons but I have no experience with them.
If it isn't necessary to have cordless, then buy a proper Iron with temperature control.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: October 29, 2010, 08:43:56 am »
just get a 12 or 18 W antex iron. Pretty neat little irons, I'm quite happy with my 12W one
« Reply #3 on: October 29, 2010, 11:51:15 am »
I thought about cordless, but then I'd have to keep fuel in the truck as well. Space is at a minimum in my Transit Connect :(
The Antex irons look like a good deal, and they're nice and small. Thanks!
Offline Simon
  • Global Moderator
« Reply #4 on: October 29, 2010, 01:41:01 pm »
and you can get a nice little selection of bits for them. go straight to their main website and you will get free delivery
« Reply #5 on: December 05, 2010, 03:53:06 am »
I just wanted to come back to this and say Thanks Simon! I got an Antex 18W G/3U and a 3/32" chisel tip (which I think will be good for general stuff). I've used it a few times and it blows anything else I've ever had out of the water! Excellent recommendation!
Offline Simon
  • Global Moderator
« Reply #6 on: December 05, 2010, 09:35:27 am »
good, yes my 12W iron is fine for any electronic assembly, I'd only need something bigger for large items
Offline tyblu
    • blog.tyblu.ca
« Reply #7 on: December 05, 2010, 11:24:57 am »
I use a little butane torch for automotive work. You can get pretty good with them and they're very quick, but it takes practice before you can use it for customers.
Tyler Lucas, electronics hobbyist
Offline Simon
  • Global Moderator
« Reply #8 on: December 05, 2010, 01:49:32 pm »
hehe I'd just use an inverter
« Reply #9 on: December 05, 2010, 10:33:02 pm »
I already have an inverter mounted in the back of my truck for chargers, so I don't need to play around with propane/butane or a 12V iron but if I did, Antex makes one.
