Looking to write a microcontroller application, I'm building a rowing computer so first version is usb, accelerometer, display, sd card. The general concept is read sensor data do some math and store it to memory & display it on screen. At some later time offload the data via usb. The SD card was a shortcut idea to avoid the usb data part on the initial go around. I'm planning to use an STM32F0 to start with. I have a SW background so I'm kinda struggling with the whole 'roll your own' approach for everything.
I'm pretty certain I need a bootloader as I want to flash firmware updates via usb. What are my options here? I found OpenBootloader but that was about it, is there anything else worth looking at?
I looked around for some kinda OS and came across the concept of RTOS, i think this is probably a bit to much for my needs but is there other maybe less heavy loop/scheduler type frameworks? (i'm hopefully searching for the wrong terms which is why i can't find much)
