Author Topic: Opamp, Mosfet, LED, Voltage Offset issue  (Read 7866 times)
Offline michaeliv
Re: Opamp, Mosfet, LED, Voltage Offset issue
« Reply #25 on: April 17, 2016, 06:26:44 am »
I found an article from Linear where they tackled the issue by placing a resistor on the output, another one in the inverting input and a cap across the output and the input.
Link to article for anyone that might be interested in knowing more details ?
Offline uncle_bob
« Reply #26 on: April 17, 2016, 11:37:48 am »
Tried it and it's spot on.
Schematic attached.
Thanks a lot!
Hi
If you check the Linear article against your schematic, there should be cap between the op amp output and the inverting input. Your schematic does not have that cap.
Bob
Offline swat3dTopic starter
« Reply #27 on: April 17, 2016, 05:22:40 pm »
Here is the article
http://www.linear.com/designtools/currentsense/19-current_control.pdf
The voltage controlled current source on page 3
Uncle_bob my latest schematic 2 posts above has the cap. I had to use a .2uF. The .1uF didn't cut it.
Offline uncle_bob
« Reply #28 on: April 17, 2016, 05:34:05 pm »
Here is the article
Hi
The schematic *has* the cap shown on it. That is true. The problem is that the cap is shown at the wrong location in the circuit. It connects between op oamp pins. The schematic you show has the cap connecting at the far end of the resistors. Simply put: It goes between pins 1 and 2 on the op amp and not across the MOSFET.
Bob
« Reply #29 on: April 17, 2016, 08:29:26 pm »
Ops, you are totally right! Sorry about that. That may be why I had to increase the capacitance.
« Reply #30 on: April 17, 2016, 10:01:11 pm »
I fixed the issue and actually ended up lowering the value of the opamp output instead of increasing the capacitance which didn't feel right. It works perfectly now.
Here are a few links that anyone running into the same issue might find useful.
http://www.electronicsweekly.com/blogs/engineer-in-wonderland/current-sink-stability-2015-10/
http://electronics.stackexchange.com/questions/69506/stability-problem-in-unity-gain-opamp
http://www.analog.com/library/analogdialogue/archives/38-06/capacitive_loading.pdf
Thanks.
