...A few points of clarification:
* RCD's can be breakers or outlets (there are a few other specialized devices out there too, but most people won't encounter them). In the US the term GFCI is much more common, but means the same thing: A device that detects and reacts to an imbalance in current.
* RCBO's are RCD's that also include overcurrent protection. Thus GFCI outlets are RCD's, but GCFI breakers are RCBO's.
* This thread has been discussing breakers, not outlets.
* GFCI outlets (usually) have a separate connection for an earth reference because three-wire appliances expect an earth reference. GFCI breakers typically do not have a (fourth) connection for an earth reference, at least not in the US. The third connection on GFCI breakers is a (usually white) pigtail that is to be connected to neutral, without regard to whether neutral is bonded locally or distantly to an earth reference. A GCFI breaker is therefore designed to function properly with, or without, a bond between neutral and an earth reference...
AFAIK RCBOs here in Australia/NZ and the UK are a combination of RCD and MCB combined, usually in a single DIN slot package with active and neutral from the N busbar coming in,
and active and neutral going out to the load/s.
The RCD section work as they should to spec and easy to verify with a decent RCD tester
The MCB section, depending on the current curve (B, C, D, or anyone's guess sometimes..
) reacts to short circuits and massive 5x > 10x current draw,
but a bit of a fail on slow-ish thermal based gradual over-current.
The 10 amp rated small breakers fitted to 4 way/6 way power boards/power strips work a lot better in that regard,
once things get ~hot~ anywhere from 8 amps to 20 amps, they will pop reliably,
whilst the 16 or 20 amp RCBO downstream fed with warm wire symptoms just sits there clueless
fwiw I use RCBO and power strip to cover all bases,
and if I need a faster and or no brainer solution, a temporary in-line fuse to suit the load or DUT
How does the GFCI thing work with 120 and 240 volts over in the US?
Do the separate 120 and 240 circuits have separate rated GFCIs, or go to a Master?
What about 208v branches?
I've seen Youtubers play with 120 <> 240 adapters to pull serious welder current or power homebrew -LightNing- rigs
are they still getting GFCI benefits if GFCI is fitted?
Will GFCIs in the US still work with a good centre tapped Neutral connection and failed Earth connection
and how reliably?
More better worded questions coming once the coffee kicks in..
