Hello everyone!
First of all, I hope I picked the right subforum, I was not entirely sure.
I am interested to understand how the wide signal input range for logic analyzers like the Saleae Logic Pro 16 [1] or
DreamSourceLab DSLogic Plus [2] has been realized.
Does one of you know more about this?
Is the specified maximum frequency supported over the full input signal voltage range on these devices?
I was thinking that the internal clamping diodes of the FPGA might be used, but I am not sure and so far I did not find further resources on this.
Could I find diodes with similar properties as external components?
The background is, I would like to build an addon-board (as open source) for the FX2LP dev board (the one which is widely used as cheap logic analizer).
Once finished, I would want the addon board to support an extended input range with high impedance and provide input protection.
I have started looking at the SN74LVCH8T245 [3], the 74HC4050 [4], and ESD Diodes in general,
but then I thought it might be good for me to gain a better understanding of already developed products first.
Thank you a lot!
[1]
https://sigrok.org/wiki/Saleae_Logic_Pro_16[2]
https://sigrok.org/wiki/DreamSourceLab_DSLogic_Plus[3]
http://www.ti.com/lit/ds/symlink/sn74lvch8t245.pdf[4]
https://www.nxp.com/docs/en/data-sheet/74HC4050.pdf
