Depends, of course. What are you switching?
Typical examples:
- 120/240V power supply, DC output, up to 1-2kW. The inverter is full bridge, with the switching controller and gate drivers on the line side. The only isolation required is an optoisolator to provide feedback and regulation. In this case, the gate drives could easily be monolithic high/low side bootstrap driver chips (IR2110, etc.).
- Same thing, but with switching controller on the output (isolated or grounded side): auxiliary isolated power is required to start the controller, and gate drive must be isolated, for example, using a gate drive transformer. The isolation required of these two isolation barriers depends on the output ground: if the output is grounded to safety ground, 2kV Functional isolation is sufficient. If the output is not grounded, and will not be connected to SELV (safe extremely low voltage -- safe to touch), Basic isolation is sufficient. (It can be connected to SELV through another Functional isolation barrier of the same voltage rating -- two layers counts as Reinforced.) If it connects to SELV directly, the isolation must be Reinforced.
- High power circuitry, like a 480VAC 3ph, 20kW motor drive. This requires 5kV isolation, but the barrier keywords work the same way. Now, this type of equipment requires much more drive than a gate drive transformer is capable of, and probably requires DC coupling to produce the correct waveforms. A GDT would be impractical, so fully isolated gate drive modules are used. This requires a Functional barrier in the power supply for each isolated driver, and a Reinforced barrier coupling signals from SELV (front panel, or PLC controls, or..) to the drivers. The latter may use standard optoisolators (cheap, relatively slow), coupling transformers (requires modulation), monolithic magnetic couplers (logic level, moderately priced, fast, and very dV/dt tolerant), or even fiberoptic cable for very high power equipment (usually in the megawatts).
Disclaimer: don't take my word for it, read the standards! I'm sure I've confused Basic and Functional, or what the algebra of cascaded isolation is, and required voltages, and so on. This is just to get some flavor of what might be done and why.
