Author Topic: How many mH?  (Read 9803 times)
Offline J4e8a16n
    • Jean Pierre Daviau
Re: How many mH?
« Reply #25 on: July 06, 2015, 03:04:28 pm »
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline J4e8a16n
Re: How many mH?
« Reply #26 on: July 08, 2015, 04:24:19 pm »
Can we calculate the  inductance    L    from these data   has  I did?
Does  the  XL interfere with the current available from the power supply to the coil?
Does it have to be added to the wire resistance wich would have almost no influence
sqrt((130.624)^2+1^2)  = 130 Ohms
1.1 volt / 130 Ohm(xl)  = 0.008  A   in the coil?
It fits with  (.888/2) / 50 = 0.008
As the current goes in the coils the flux climbs to 1.9 volts or more and discharge the current in the led when the transistor goes in saturation.
If in the first time constant, let's say there is .5 A and the led uses only 50mA, does the flux 'wait'?
Thanks
JP
« Last Edit: July 08, 2015, 11:01:17 pm by J4e8a16n »
