I'm working on designing a subsonic (~25Hz high pass) filter for car audio purposes. Basically I'm making a ported box for my subwoofer, and need to avoid overexcursion below the port tuning frequency. Since the subwoofer is very high power I really need to do this in the line-level RCA inputs to the amplifier.
My idea is to use some op amps for the job. First a buffer, then the second-order high pass filter, then perhaps another buffer just in case. Since I only have +12V for power, I'll need to generate a negative voltage rail. I figure an LT1054 should do the job? Then +9V and -9V linear regulators to get something stable?
My main concern is I have absolutely no idea how to handle differences in signal ground (the RCA shield, this is an unbalanced signal) and chassis/power ground. I am a complete newbie with op amps, so I'm a little clueless here. Do I just reference the op amp signals to the signal ground, tie the output RCAs to signal ground, and use chassis ground for the power supply portion? Do I need to tie the signal ground to my chassis ground? Could I somehow be creating a (unwanted) DC offset on the output? Or am I just overthinking everything here.
Thanks!
Edit: Alternatively, I could do a balanced output signal if that would simplify everything, but I'd prefer to avoid it if it's not necessary. I have no idea how good (or not good) the balanced receiver is on the amplifier input.
