Enough about tools, here are some empirical results of using the three styles of crimpers I have on 14 ga. wire and "blue" (16--14 ga. recommended) 1/4' spade terminals--I also threw in a "ringer", my "finest kind" tool i use for non-insulated terminals (or after removing the insulation):
all four (left to right, squashed, staked, full compression, the "ringer")--what I will call the "top" side...
all four (left to right, squashed, staked, full compression, the "ringer")--what I will call the "back" side...
the three insulated terminals--insulation removed (left to right, squashed, staked, full compression)-- "top" side...
insulated terminals--insulation removed (left to right, squashed, staked, full compression)-- "back" side...
Note: I could have better positioned the "stake", but it looked OK with the insulation on.
Micrographs of all:
squashed (top)...squashed (back)...staked (top)...staked (back)...full compression (top)...full compression (back)..."ringer" (top)..."ringer" (back)...So, what is the "ringer" you ask?
It's a tool made for non-insulated MC4 barrel connectors commonly used in solar panel installations:
It makes the prettiest, most secure crimps of any hand-held tool I have--throw some heat shrink tubing on this puppy and never worry about it, ever again...
And--just for the sake of completeness--here is what the 10-ton hydraulic swager does to a 6 ga. ring terminal:
