A: Exactly half the combined weight of two identical resistors!
Quote from: Uncle Vernon on January 22, 2011, 03:27:00 amA: Exactly half the combined weight of two identical resistors! average. since there is no technology that is capable of making two pure identical resistor, molecularly
why you want to know? the only business that i can think of that do care of the weight of such small item is in the space industry.
Which is heavier a ton of lead, a ton of feathers or a ton of helium?
Well now you have posed quite a conundrum. If this is correct it will not be possible to quote a weight for resistors only the weight of a resistor. Each item from the OPs job lot will need to be weighed individually.
