Author Topic: soldiering iron advice  (Read 2202 times)
Offline peterthenovice
  • rip the other half out put in a bread board
« on: March 15, 2013, 04:23:14 am »
I found this iron on ebay its a hakko clone with rework gun and a 1 amp 1-15v power supply. for 109 us dollars.I want to upgrade from my
plug it in heat it up  slowly from radio shack.
hers the ebay link:
http://www.ebay.com/itm/853D-3in1-SMD-Soldering-Iron-Hot-Air-Gun-Rework-Station-DC-Power-Supply-Digital-/300861005053?pt=LH_DefaultDomain_0&hash=item460cb69cfd
here is a youtube link:
« Last Edit: March 15, 2013, 05:22:03 pm by peterthenovice »
a craftsman multimeter, bk precsion scope
Re: soldiering iron advice
« Reply #1 on: March 15, 2013, 05:23:01 pm »
I have updated my post to make more sense.
Offline nanofrog
« Reply #2 on: March 15, 2013, 06:21:14 pm »
Why the two different threads (repeated here: https://www.eevblog.com/forum/chat/soldiering-station-advice/?topicseen)?  :-\
Offline micro_freak
« Reply #3 on: March 16, 2013, 10:43:48 pm »
Ok for hobby,  do not expect the build quality of a professional grade station.  Definitely not as good as hakko or jbc,  but for a fraction of the cost,  it will do adecent job. If you use it once a month
, it will last at least a decade.
Offline jtorba
« Reply #4 on: March 17, 2013, 05:59:56 am »
Save up for the hakko one, it is always LOADS better.
Offline Dylogic
« Reply #5 on: March 17, 2013, 04:40:06 pm »
That 3in1 station is realy nice but if you blow the power supply can you still use the soldering iron and the hot air gun? and for only 109$ for this for soldering Iron, Hot Air, DC Power Supply it a good deal but I am sure real Hakko soldering station will do so much better and be much durable.
« Last Edit: March 17, 2013, 04:41:51 pm by Dylogic »
