Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
what is the use for 2 cathodes in an triode?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: what is the use for 2 cathodes in an triode? (Read 832 times)
ELS122
Frequent Contributor
Country:
on:
February 02, 2020, 12:50:40 am »
what would someone use 2 cathodes for?
I found this 6Г7 tube that has 2 cathodes and don't see it useful.
Logged
schmitt trigger
Super Contributor
Country:
Re: what is the use for 2 cathodes in an triode?
Reply #1 on:
February 02, 2020, 12:52:35 am »
It would be very interesting if you post the tube schematic.
Perhaps as a mixer?
Logged
ELS122
Country:
Reply #2 on:
February 02, 2020, 12:53:44 am »
datasheet :
https://www.gstube.com/data/430/
shematic where I found it :
https://www.gstube.com/schemes/pics/Ra/Belarus.GIF
also I don't really want to know how is it used in the shematic but what can it be used for
Last Edit: February 02, 2020, 12:58:05 am by ELS122
Logged
ArthurDent
Super Contributor
Country:
Reply #3 on:
February 02, 2020, 01:18:19 am »
That is a multipurpose tube with one cathode, 2 anodes, plus a triode. Tubes like this were used the diodes for the detector and automatic volume control (AVC) and the triode for the 1st audio amp in a receiver. Here is a similar tube.
https://frank.pocnet.net/sheets/093/6/6SQ7.pdf
Last Edit: February 02, 2020, 01:23:50 am by ArthurDent
Logged
ELS122
Country:
Reply #4 on:
February 02, 2020, 01:24:17 am »
wait so it's basically a diode connected to the grid of the triode?
I don't understand this at all.
https://www.radiomuseum.org/images/tubeenvdiag_klein/cv5876qgnr68_appa~~3.png
also it says in that shematic that 1 of the cathodes go to the signal diode and plate to the output
how is it?.. what???
Logged
ArthurDent
Super Contributor
Country:
Reply #5 on:
February 02, 2020, 01:39:04 am »
You are not understanding what I have said or the datasheets have described. Here is the tube redrawn to make it obvious.
Logged
ELS122
ELS122
Country:
Reply #6 on:
February 02, 2020, 01:43:58 am »
oooooooohhhhhhhhhhh...
how did I not see the cathode down there and thought that those 2 plates were cathodes
thanks, now I get it!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
