If you want something which will do a large range of jobs,get a Weller WTCP.
They are way too expensive new,but if you can pick up a good used one,you will be agreeably surprised.
The main fault to look out for with these,is that the magnetic switch can stick on & the thing gets too hot!
Obviously it would be nice to have a really nice "Soldering Station",but it is not as essential as many "fanboys" on this forum assert.
Most people reccommend the Hakko 888,which looks like a nice unit.
The only Hakko stuff I used ones were not too marvellous,but that was a few years back,& ,knowing the employer's ways were probably the cheapest & nastiest-----the ones that Hakko "are trying to forget"
With the vacuum desoldering setups,the only ones I've had much to do with are Pace & Royel,& they both use a vacuum pump.
VK6ZGO
