Yes, I always tin my boards shortly after etching them so the copper doesn't tarnish. It makes soldering components to the board easier too. "Tinning" in my case is nothing more than fluxing the board and running a soldering iron (that's had some solder applied to it) along the traces and trying to keep the solder as thin as practical.
As you can see, it's hard to create a completely level surface this way so, just before I solder on a part, I make sure all the pads are fairly level by wiping away any excess with some flux and a clean tip. (I use solder wick on pads this small only as a last resort to avoid lifting the pad.) The pads with a little extra solder can be handy for tacking-down the part too.
So, to answer you question, no, I don't have any problems. This is the smallest pitch that I use for my homemade boards, though.
