Hello
I'm trying to find out data about the following 3 filters and it seems that google is not returning anything useful:
If there is no data available, could i use the following procedure to determine input and output impedance, considering that i have a nice RF signal generator available ?
1. set the signal generator to 10.7MHz, 0dBm
2. use a BCN T connector to split the signal to an oscilloscope and to a filter
3. measure the open voltage on the scope ( filter not connected ) - peak to peak for example
4. connect the filter and measure the new generator voltage
5. change the frequency around the pass band to determine width, etc - i have a AD8307 log detector for that ( i need to calibrate it for 10.7MHz )
Determine Rfilter from the generated voltage divider knowing that the generator has 50 ohm output impedance - if RFilter is large ( 2-3k ) it might not be too precise.
Is the filter symmetrical ? can i consider the output impedance equal to the input one ?
