I am trying to build a simple low noise linear power supply based on a LT3083.
I want to be able to set the voltage range at least from 3.3V to 9V but even better from 1V to 12V
According to the datasheet I would need a variable resistor of 20k per volt controlled, so a 220k potentiometer in series with a 20k resistor would be ideal.
However, searching on eBay, I can't find any Bourns 10 turn potentiometers above 200k and only one very expensive ($35) 200k.
Now I do have a good quality high grade 100k Bourns 10 turn potentiometer, but I can't figure out a way to have it behave like a 220k
I was wondering if there's a simple and easy way to get the desired result with a 100k pot? It just has to provide resistance to ground in such a way that the LT3083 can 'drain' it's 50uA of constant current with the desired voltage drop over the variable resistance (20k per volt)
I'm really looking for a simple solution with a 1 or 2 commodity parts
Any ideas?
