As the image shows, The capacitance of the circuit will be the two capacitors in series, which is 135nF.
So the time constant will be t = R * C = 520ohm * 135nF = 0.7us, but in the oscilloscope the charging time is obviously more than 3.5us(5t)
I've build a current source using an op-amp.This current source circuit is always used in DC.
But i tried to make it work in AC by simply adding two capacitors(to isolate DC offset).From the simulation, it seemd working properly.
Then I want to calculate the time constant of this circuit, but the result contradicts the oscilloscope's graph.
The op-amp is ideal, whose output resistance is 10ohm. And it has connected to +12V and -12V DC supply.
Fuction generator is set to output a 1kHz sqare wave at 5V(peak-to-peak).
Did I calculated correctly?How to analyze this circuit?
I'm a beginner in electronics, I'd be appreciate it if you can help me.
