Author Topic: Sanity check - FET H-Bridge circuit  (Read 3891 times)
Online exe
  • self-educated hobbyist
Re: Sanity check - FET H-Bridge circuit
« Reply #25 on: September 12, 2018, 08:19:00 pm »
Another question is why bi-color LED requires inverting voltage across it :). Never seen such.
Also, not all LEDs sustain reverse voltage. Some break down at around 5V. Worse yet, most datasheets don't provide such information.
Offline danners430Topic starter
  • Good at overcomplication
« Reply #26 on: September 12, 2018, 11:02:01 pm »
Look up any 2 lead bi-colour LED :-) it's literally how they're designed to be operated.
I'm really wanting to use the H-Bridge to learn about them; aye, I could go with driver ICs etc, but I'm on a learning curve and would prefer to learn how things operate before using ICs for everything. For example up until now I've gone with transistor outputs for every LED channel, and it's only now I'm using a multiplex IC to drive them instead :-)
Sent from my ONEPLUS A3003 using Tapatalk
