I'm a beginner in LTSpice and I can't figure out how to tie an LT1021-7V reference to my circuit and then look at the total noise.
I'm developing a reference buffer to scale a 7V reference to 10V.
The reference buffer must be idiot proof and have the lowest possible noise contribution.
There are some more requirements I have but that will come later when I show you the whole thing here on the forum.
The schematic below is not complete, the protection is not in the schematic.
First the schematic where now is an LT1021-7 is placed at the input of the buffer and the not working comand for measuring the noise.
The picture below is of the noise behavior of a noiseless 7V voltage source so not the LT1021-7, this is my reference.
The intention is that I want to see the difference with a real reference, so I don't have to make adjustments if the reference circuit used, if the LT1021-7 or other Reference is dominant for the noise behavior of the whole circuit.
So I would like to know if it is possible, of the present voltage references in LTSpice, to show their noise in my schematic and how I do it in the simulation command.
This command that I already modified in several ways does not work:
.noise V[Vout] U3 dec 100 1 1000Do the voltage reference in LTSpice have a noise parameter?
Thanks
Kind regards,
Bram
