I'm building a circuit with a ZTT 20.00 MX and had some questions regarding the frequencies I was getting. The datasheet says that MX's are 13.01-50.00MHz and that the "20.00" indicates a 20.00 MHz frequency. However, in the circuits I built, the largest frequency I got from the attached schematic was 4.4MHz. The 4.4MHz was the value of the circuit where the dampening resistor was left off. I was expecting a higher value. I'm using 5V to power the CD40106BE Hex Schmitt Trigger IC.
I'm also wondering if the circuit I built with the 50k dampening resistor (shown in the schematic) is correct for the output of my scope (270kHz shown in scope screenshot).
Thanks,
Carl
