You need to understand how the circuit works. A well-designed circuit will minimise the dependencies, but can't eliminate them.
If you can't understand the (analogue?) circuit, you could simulate with, say, LTSpice. You could manually tweak component values, or set it up to do monte-carlo simulations.
