Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to clear output of step up converter ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to clear output of step up converter ? (Read 1604 times)
Matthew98
Regular Contributor
Country:
on:
February 21, 2017, 08:15:55 pm »
Hey. I bught a DS0150 mini osciloscope and moded it to have internal battery. Its 700mAh Lipo and Im feeding the scope, which draws 100mAh at 9V by step up converter. but this converter add significant amount of static to the osciloscope. How do i get rid as much of it as possible ?
For now im using only 470uF capacitor as filtration ... dunno what to add
Thanks !
Logged
bharatcs
Contributor
Country:
Re: How to clear output of step up converter ?
Reply #1 on:
February 22, 2017, 06:14:59 pm »
Hi
Capacitor can only filter the output voltage.Since the step up converter is a switching circuits it will produce electromagnetic interference as it is not shielded and can induce voltages in the input circuitry oscilloscope thus creating static.
To solve your problem you can
-Try to move the step up converter away from the main circuit
-Try some shielding method (not sure how to )
-Proper grounding
Logged
Matthew98
Matthew98
Regular Contributor
Country:
Reply #2 on:
February 23, 2017, 01:06:28 pm »
I will try to shield him than..
Mabye aluminum foil will work... I ll have to try
Aluminium and iron plates together make a good shielding, they say...
Last Edit: February 23, 2017, 01:56:39 pm by Matthew98
Logged
Matthew98
Regular Contributor
Country:
Reply #3 on:
February 24, 2017, 09:06:36 pm »
Update : Its not inducted voltage. I have tried powering it from 9V battery and when i turned on the stepup converter and gave it 100ma, the scope was sill clear.
Altough i have figured out something. If I connect the step up converter via long (half a meter ? ) cables, the noise decreases a lot !
Logged
Refrigerator
Super Contributor
Country:
Reply #4 on:
February 25, 2017, 05:18:06 pm »
if the current draw is only 100mA then you can put a small inductor in series with the boost converter.
Logged
I have a blog at
http://brimmingideas.blogspot.com/
. Now less empty than ever before !
An expert of making MOSFETs explode.
Matthew98
Matthew98
Regular Contributor
Country:
Reply #5 on:
February 26, 2017, 12:32:11 am »
how many H do you reckon ?
Logged
Refrigerator
Super Contributor
Country:
Reply #6 on:
February 26, 2017, 08:52:07 am »
47µH inductor would be a good place to start.
Also it would help if you put about 10µF capacitor between the scope and inductor to ground.
Last Edit: February 26, 2017, 08:57:37 am by Refrigerator
Logged
I have a blog at
Matthew98
Matthew98
Regular Contributor
Country:
Reply #7 on:
February 26, 2017, 01:25:47 pm »
Thanks !
So i gave it twice bigger inductor, as i dont have any smaller right now, but it works really well !
I did small module out of it, so it can fit inside with no problems. here is how the module looks
And it scopes quite nice now
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
