I'll try to answer all the questions here, to clear up confusion.
Worded the original post very badly, and didn't fully understand the circuit. I was worried about the little arrow in the picture.
I'm sure all of you know what that means, so I wont bother explaining it, but I have an IGBT that has the arrow going in the other direction, hence the current going in the other direction. Can i connect the IGBT same as the MOSFET, or differently? Or will an IGBT not work at all in this circuit?
Not only is there no PNP transistor in the circuit, but there is also a switch in series with the inductor L3 which is not a good idea because when it is opened the inductor could generate a huge voltage kickback and cause problems.
I'd have to ask where you got this circuit and what is it supposed to be used for.
Thanks for mentioning the voltage spike when disconnecting the switch. Would it be better to go with no switch?
It also looks as if it may be powered directly from the mains (220V) making it extremely dangerous.
It is supposed to be powered off 220v, which is super-super dangerous. For this reason if I ever run it, I will wear the proper protection.
Unless L1 and L2 are on the same core and that core also has another winding (secondary) that power is extracted from, that would be the most useless design I have ever seen. And why, when looking at that symbol did you guess it was a transistor? It is the industry standard symbol for a certain style of FET. N type devices in 99.999% of circuits can't be swapped with P type devices and vice versa unless the polarity of the power supply is also reversed. No fuse in the circuit = nice explosion when the FET shorts due to no snubbing circuit or failing to begin oscillation at all.
Sadly, I don't know all of the symbols just yet, sorry about the confusion there. And thank you for recommending a fuse, which I will definitely add into the circuit. But if a snubber (I'm assuming that it would be a resistor and capacitor, parallel to the switch) were to be added, what should the values of the components be?
Sorry for all of the confusion, I will try to understand and answer all of your answers as precisely as I can
