What is the typical cord arrangement?
- Mat to ground and wristband to mat(somehow,
there is only one connection point on this mat, a snap-button.)
In this case you can do two pretty simple things. 1. Make a slitter for the snap-button and connect mat to ground from one end of the split and the wristband to the other. 2. Just get a spare button-snap and insert it to the mat. Many videos on this on youtube. If you go with the 2nd route you can connect the mat to ground from the first button-snap and your wristband to mat via the second one.
- both wristband and mat straight to ground
You can do this as well since both the mat and wristband have the 1M resistors built-in. The only problem here would be you would probably need an extra long cord for the wristband? The cord would get tangled up?
- wristband to the workpiece and mat to ground.(but if workpiece has poor contact with the mat or is largely dielectric?)
I suggest going with the wristband on your wrist. 1. Your body would be discharging any built up static when working on the piece 2. You always remember to put the wristband on if it is sitting on your mat vs. just shift it aside and start working.
- Did I forget to order some missing connector dodads?
Maybe just order an extra button for the mat?
The way I setup my ESD mat was with two connection points. First one was for mat to ground and second was for wristband to mat. On the outlet I have a dedicated ESD-plug (
http://www.esdshop.eu/pictures/vyrobky/1obr_1226.jpeg). I also connect my ESD-storage and such to that same plug. Plug also has a 1M resistor built-in, so I don't really need to worry if I plug a cheapo chinese strap to the mat.
