Author Topic: How to connect this sensor??  (Read 1281 times)
Offline LostElectronTopic starter
« on: July 24, 2018, 10:43:28 am »
Hi folks :)
I want to connect this sensor to this wire. Unfortunately no solder should be used (high temp).
I just can't find a ceramic conector or some kind of crimp among the billions of connectos at Mouser :(
Any ideas??
Offline austfox
Re: How to connect this sensor??
« Reply #1 on: July 24, 2018, 12:11:22 pm »
« Reply #2 on: July 24, 2018, 01:18:31 pm »
I wish...
But its a temperature sensor, so it will be exposed to +200C.
So no soldering nor plastic :(
I think I found a solution... but ist very very DIY.
Offline JS
  • Country: ar
« Reply #3 on: July 24, 2018, 01:34:46 pm »
Maybe you can weld it, like a thermocouple junction, small electric welder with carbon electrode could do. Or spot weld it. Then use high temp insulator.
JS
If I don't know how it works, I prefer not to turn it on.
Offline tooki
« Reply #4 on: July 24, 2018, 04:43:58 pm »
What about using uninsulated crimps, like a butt or a ferrule?
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #5 on: August 09, 2018, 04:34:50 am »
cover the sensor with wer sponge and use solder to connect it to a pcb chunk.
Offline Jwillis
« Reply #6 on: August 09, 2018, 04:46:43 am »
2 Pin Female Single Row Straight Header Connector
