My computer recognises it , it shows up as digispark bootloader in the device manager.
the problem is : I cant understand if the IDE even running correctly.
I chose the "use Arduino as an ISP" as the programmer (the only programmer that won't error about missing device or port) it shows :"Uploading..."
for several minutes and then "avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03".
the Digispark instructions says that "Programmer selection does not matter" so what is wrong ?
also I hooked up an led to pin 4 of the chip,it blinks when I plug it in to a computer (connected to USB),but nothing happens when I try to program it using the IDE.
