Author Topic: How to detect -5 volts?  (Read 1210 times)
Offline rea5245Topic starter
« on: January 18, 2019, 03:52:37 pm »
I have a connector that can plug into two slightly different devices. I want to automatically detect which device it's plugged into. With one of the devices, there is -5V (yes, that's minus 5 volts) coming in on a pin. With the other device, that pin is not connected to anything. I can't connect the pin directly to a microcontroller, because -5V would damage it. What can I do to get a 0 or 1 signal to the MCU based on whether the -5V is there or not?
Thank you,
   Bob
Offline PartialDischarge
Re: How to detect -5 volts?
« Reply #1 on: January 18, 2019, 03:57:14 pm »
4.7V zener to the pin, then a pull up 100k resistor to the mcu. If not connected to anything the mcu will see 5V, if -5V is present at the pin, the mcu will see 0
« Reply #2 on: January 18, 2019, 04:00:08 pm »
Will the MCU's built-in weak pull-up suffice, or do I need the 100K resistor?
Offline schmitt trigger
  • Country: mx
« Reply #3 on: January 18, 2019, 04:08:53 pm »
The weak internal pullup may work. Having said this, common resistors are ultra-cheap. And if you are using SMT devices, ultra-small too.
My personal opinion is that for this instance I would use an external pullup. But other posters may think otherwise.
« Reply #4 on: January 18, 2019, 04:14:04 pm »
The internal may be enough, but anyway I would also add a series resistor with the zener to limit the current in the mcu, just in case your -5V turn out to be -7 or -10V someday
« Last Edit: January 18, 2019, 04:17:29 pm by MasterTech »
Online coppercone2
« Reply #5 on: January 18, 2019, 04:23:46 pm »
its good form anyway because its a external device and all external IO should be protected if possible by design, it will reduce the ESD some what.
Offline macboy
« Reply #6 on: January 18, 2019, 05:14:46 pm »
Connect 10k to micro's +5V rail, other end to a microcontroller input pin AND to the device pin via another 10k resistor. When device drives that to -5 V, then the voltage divider makes ~0 V, or logic low to the local micro. Otherwise it floats to +5 V, logic high. A zener (or better, a TVS) to protect the micro's input would be prudent, but its own input protection diodes plus the 10k resistor may be enough.
Offline spec
  • MALE
« Reply #7 on: January 19, 2019, 05:47:41 am »
Hi rea5245
Another approach:
« Last Edit: January 19, 2019, 05:52:30 am by spec »
