Author Topic: What do I use to hot snot connections in place?  (Read 2138 times)
Offline FearTecTopic starter
  • Coding Arduinos etc, 90% electronics newbie.
    • Personal Blog
« on: September 13, 2020, 10:12:34 pm »
What do I use to hot snot connections in place?  I'd prefer not to use hot glue guns and I'd like to know what the professionals use (dark blue or red stuff that is often in Daves tear downs)? I don't want to super glue or araldite either
Thanks in advance
Coder and electronics newbie.
Online wraper
  • Country: lv
Re: What do I use to hot snot connections in place?
« Reply #1 on: September 13, 2020, 10:21:10 pm »
The cheapest would be to order silicone for electronics from China. Usually sold under 701-708 number from various manufacturers. Can order from aliexpress or ebay.  Western companies sell them only in large tubes for a lot of money.
https://www.aliexpress.com/item/4000416228722.html
The following users thanked this post: BravoV, FearTec, SilverSolder
    • Personal Blog
« Reply #2 on: September 13, 2020, 10:29:45 pm »
Thanks for the quick reply wraper
I'm a beginner and got my first N Channel MOSFET firing a high amp (8) solenoid and I want to limit vibrations.
Ordering now.
    • Personal Blog
« Reply #3 on: September 13, 2020, 10:46:18 pm »
Thanks I ordered 3x tubes of the 704
« Last Edit: September 13, 2020, 10:48:04 pm by FearTec »
Offline wizard69
« Reply #4 on: September 14, 2020, 02:51:55 am »
This is another it depends question.   RTV is great for many applications but it doesn't always stick well to some materials.   Even so I will go the RTV route before anything else.   I've actually used RTV to pot wiring into the the back shells of DB connectors that seem to fail way too fast.
In some cases I've used good ole fast setting epoxy.   Epoxy is good for repairing things that may have been torn out of a board like thread inserts, brackets and the like.   In this case I like the "double Bubble" packs from Hardman / Royal adhesive, which apparently has been purchased by H.B. Fuller.   Fuller's web site sucks unfortunately.   In any event the double bubble packs usually have enough for the small repairs common in maintenance.   Just make sure the epoxy is compatible with what you are gluing together.
As to other materials the various enhanced super glues from the likes of 3M or Loctite can be very useful.   Both of these companies have all sorts of stuff for the PCB industry that I've never used.   It can pay to download a catalog to simply learn what the companies offer and to see if any are available in the minor quantities you require.
The following users thanked this post: FearTec
Online wraper
  • Country: lv
« Reply #5 on: September 14, 2020, 03:09:15 am »
Don't suggest that on electronics. Superglue is slightly conductive. Also expoxy and superglue is not something you want on things you may need to repair or modify afterwards.
Offline Rasterist
« Reply #6 on: September 15, 2020, 04:46:18 am »
For anyone:  what are the problems with ordinary hot glue when used in this application?
Offline SmokedComponent
  • Country: si
  • Emitting smoke
« Reply #7 on: September 15, 2020, 03:39:18 pm »
Spray some isopropyl alcohol or contact cleaner on hot snot and that will demonstrate you where to use and where not to use hot snot. :)
Online wraper
  • Country: lv
« Reply #8 on: September 15, 2020, 03:53:01 pm »
Unreliable crap. It will delaminate within a few years. When used in cold environment may happen within a few days. Or will soften/melt in hot environment.
Offline SilverSolder
« Reply #9 on: September 15, 2020, 07:54:33 pm »
This effect is used for the force of good, in Paintless Dent Removal!  :D
Offline tooki
« Reply #10 on: September 16, 2020, 05:31:05 am »
Thanks in advance
Well, the snarky answer is that you must use a hot glue gun to hot snot something into place, since “hot snot” is a synonym for hot melt glue, and thus no other type of adhesive can qualify!  ;D
Realistically, silicones are the typical adhesives used, but they must be neutral curing types, since you don’t want the acetic acid curing type releasing acetic acid onto or near electronic components.
For wires, I prefer to use tape or zip ties, etc. To reinforce stress-prone wire attachments, heat-shrink tube.
« Last Edit: September 16, 2020, 05:33:41 am by tooki »
« Reply #11 on: September 16, 2020, 12:19:11 pm »
For home/hobby projects, there is a low cost and convenient option:  non-acetic cure silicone from the local hardware or big box store.
General Electric (GE) Silicone II is very good and available everywhere.  It comes in handy 2.8 fluid ounce tubes, both clear and white.  Just make sure it says "Silicone II" on the container, or you will be getting the acid cure type!
