Author Topic: A manual reset thermal cutoff switch  (Read 1269 times)
Offline wirehead_freenodeTopic starter
« on: September 15, 2020, 12:07:46 am »
Hello, I have a device I'm planning to make that will get hot after prolonged use. To prevent it from getting too hot, I would like a 80 degree celsius thermal cutoff switch that requires a manual reset. Can someone please find one that is sub-$10 USD? I am not sure if I'm naming it correctly either.
Thank you for your consideration.
Edit: found solution at https://www.aliexpress.com/item/32982877641.html?spm=a2g0o.productlist.0.0.672168c0ZU5fed&algo_pvid=e2da7d90-f671-41de-b750-fe7a4b31b0d0&algo_expid=e2da7d90-f671-41de-b750-fe7a4b31b0d0-50&btsid=0bb0624516001296891754952eb366&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
« Last Edit: September 15, 2020, 12:31:46 am by wirehead_freenode »
Offline Rasterist
Re: A manual reset thermal cutoff switch
« Reply #1 on: September 15, 2020, 04:42:12 am »
How do you manually reset that?
If your device has a microcontroller you could have it monitor any of a number of different kinds of temperature sensors (digital or analog) and take appropriate action when the threshold is crossed.
Offline Jwillis
« Reply #2 on: September 15, 2020, 08:07:03 am »
Those particular thermal switches are not designed for repeated use . Like many thermal breakers they weaken quickly with repeated use . They are designed as a saftey device in case of catastrophic failure that would prevent a cool down.
I don't know what type of circuit you are making but with proper passive and /or active cooling any circuit or device need not become so hot that a saftey device trips with regular use.
Offline Doctorandus_P
« Reply #3 on: September 16, 2020, 09:54:10 am »
You can remove all the spam from the ali links i.e:
« Reply #4 on: September 16, 2020, 01:27:55 pm »
It's a manual reset. A pushbutton resets it.
I don't intend for the temp cutoff to trip repeatedly, just maybe once in a blue moon if someone leaves the device on. Like a hairdryer.
