It is indeed referring to old 'STN' passive LCD's. Thus the 'monochrome' in the title of that section.
These required 4-bit data, data clock, line clock, frame sync etc.. For displays >320x240, such as the 640x480, they were split into upper and lower sections that were updated at the same time, so the data interface was 8-bit: 4-bit upper panel, 4 bit lower. I have one such display and they are remarkably hard to find controllers for! But they are old old, slow and depreciated.
As you're using a TFT display then you should be using 'LCD_TFT' bit in the control register.
