Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to determine which component is the right one
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to determine which component is the right one (Read 3760 times)
hawken
Newbie
on:
July 12, 2011, 07:47:06 pm »
I'm working on a small project, which involves fixing a power supply board from a monitor. I can see one component on the board that blew up which I'd like to replace--it's a six-pin transistor of sorts. It looks something like this:
Printed on it is "F1 H01" and below that "CM0565R". I've done some searches for "CM0565R" thinking that it is the model number, and it looks like I'm at least partially correct. The problem is that there seem to be several variants of this component, and I have no idea which is the one I need.
Can anyone give me some tips to help me choose the correct replacement?
Logged
Bored@Work
Super Contributor
Country:
Re: How to determine which component is the right one
Reply #1 on:
July 12, 2011, 08:02:52 pm »
The one that has the same package as your broken one, as per page 3 / figure 3 and pages 16, 17, and 18 in the datasheet. You did read the datasheet, didn't you?
Logged
For all else:
Profile->[Modify Profile]Buddies/Ignore List->Edit Ignore List
hawken
Newbie
Reply #2 on:
July 13, 2011, 11:43:18 am »
Nope, I didn't read the datasheet. I'm a complete n00b about this. If I knew to do that, and knew how, I probably wouldn't be in here asking the question I asked.
The datasheet lists several variants (e.g. 565RJ, 565RI, 565RG), and I don't know how to tell which is the one I've got.
Logged
GrumpyDave
Contributor
Reply #3 on:
July 13, 2011, 12:25:35 pm »
As BoredAtWork pointed out.
On page three of the datasheet it shows three packages.
G matches the part you have photographed (TO220).
Logged
Armin_Balija
Regular Contributor
Country:
Reply #4 on:
July 13, 2011, 03:58:33 pm »
Datasheets are your best friend. Read about the component you posted, compare to others that you've found, pick best replacement.
Logged
hawken
Newbie
Reply #5 on:
July 14, 2011, 02:54:40 am »
I'll do my best. As I mentioned in my post, mine isn't a G--it shows as H01. That's not listed in the data sheet.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
