Author Topic: How to diagnose an opamp is broken  (Read 631 times)
Offline hp3310aTopic starter
« on: November 26, 2024, 05:51:39 pm »
  is there a simple way to tell an opamp is faulty? I've managed twice to kill an opamp by mistake - maybe due to incorrect connections including of power supply lines, maybe due to ESD, maybe due to disconnecting of power while the signal was still turned on.
In both cases it didn't occur to me that the sudden strange behavior of the circuit that worked just fine yesterday is because the opamp is dead. Exchanging the opamp eventually fixed the problem, but I had no way to verify it is dead. I would be great if there was a way to tell before I go and solder another $10 opamp onto a new prototyping SMT adapter.
The opamp in question in my case is the AD8034 (data sheet here https://www.analog.com/media/en/technical-documentation/data-sheets/AD8033_8034.pdf)
« Last Edit: November 26, 2024, 05:55:49 pm by hp3310a »
Offline schmitt trigger
  • Country: mx
Re: How to diagnose an opamp is broken
« Reply #1 on: November 26, 2024, 06:54:34 pm »
Wire it as a unity gain buffer, and on the noninverting input connect a potentiometer such that you can vary the input voltage from Vcc to Vee. Monitor the output, it should follow the input, as long it meets the I/O limits.
Offline fzabkar
« Reply #2 on: November 26, 2024, 07:21:27 pm »
A quick in-circuit check would be to verify that the inverting and non-inverting inputs are equal, if the op amp is in its linear operating mode. A typical failure mode is when the inputs or output are stuck at ground (single supply) or the supply rails (single or dual supply).
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #3 on: November 27, 2024, 12:16:08 pm »
Just a note -
AD8034 is a FET input opamp. Using it solo in SMD prototype adapter is a fastest way to kill it - it very ESD sensitive device.
Add a pair of back-to-back diodes across opamp inputs and high valued resistors from input to ground and between power rails. It will help opamp survive been soldered on adapter
Offline BILLPOD
« Reply #4 on: November 27, 2024, 01:42:55 pm »
Good Morning Hp3310a,  I too have murdered many an op amp, so instead of soldering it directly to a board, I solder in a socket and plug the op amp into the socket.  Easy to swap out with a known good one. :popcorn:
« Reply #5 on: November 27, 2024, 03:59:42 pm »
Thanks everyone for your suggestions. Turns out I only murdered one of them and the other is still working. The issue seems to be that I get a lot of high power noise into the opamp input and that's what causes the malfunction of the rookie circuit. Before this began it worked fine and I have no idea what I changed that causes this.
I would love to do that if only I understood how that is supposed to work. Wouldn't that connect the inputs to ground via one of the two diodes depending on the polarity of the signal?
Pretty sure that's not it, but what is it then?
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #6 on: November 27, 2024, 04:06:17 pm »
No, between inputs (+ and -). It will limit differencial voltage
« Reply #7 on: November 27, 2024, 04:43:01 pm »
OK, thanks! But...
That's not all I didn't understand apparently. I still don't understand the emphasized portion of your suggestion.
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #8 on: November 27, 2024, 04:45:08 pm »
This is a path to ESD discharge through resistor, instead of internals of opamp
« Reply #9 on: November 27, 2024, 05:08:21 pm »
OK, thanks, I think I understand.
