Author Topic: Where to find toggle switch parts?  (Read 608 times)
Offline monsunsiTopic starter
  • Country: si
« on: January 26, 2022, 09:21:06 pm »
Hi guys,
I was scouring the internet to find parts for a simple toggle switch. Not all of them, just the following: bushing, plunger, lever/handle. Ideally the lever/handle is brass coated with chrome and the bushing brass coated with nickel. Type of plunger is really up for debate, whether its a rod or a ball on a spring..
The idea is, I want to create a custom solenoid toggle switch and really don't want to go for anything off the shelf.
I've found a few things on indiamart but don't want to use anything from there. EU/US/China is fine though.
Any idea where to get these parts or do I have to find a chinese company that will manufacture them?
Thanks for your help!
Offline jpanhalt
Re: Where to find toggle switch parts?
« Reply #1 on: January 26, 2022, 09:30:36 pm »
Buy a new switch.  It is just not economic reality to sell individual parts.  Now, if you only need a new mounting nut, that is a different story.  Let us know.
If you want to create something "novel" then scavenge parts from existing switches or make your own.
« Last Edit: January 26, 2022, 09:32:22 pm by jpanhalt »
Offline Neomys Sapiens
« Reply #2 on: January 28, 2022, 01:13:48 am »
Are you referring to a toggle switch with a holding coil? You are aware that they exist?
