Author Topic: Resistors on the digital in/output of a PGA2310 chip, why?  (Read 2323 times)
Offline MarkS
Re: Resistors on the digital in/output of a PGA2310 chip, why?
« Reply #50 on: September 06, 2024, 02:30:12 pm »
https://youtu.be/vALt6Sd9vlY?si=lfLOLMF_B2ab5S6C
btw - you can safely remove the si=... part of the url -- it is simply a tracking identifier.
True, but I posted it at 4:30 AM and just copied and pasted.
Offline Dan R. HansenTopic starter
« Reply #51 on: September 07, 2024, 09:23:14 am »
In regards to the split ground, watch this. It's worth the time.
It seemed like it had a lot of interesting information, if the guy is right.
From what I understand, in my specific case, I would actually want split ground plains because of the low frequencies that occur in audio.
But I am still in doubt as to what way is the best to bridge the ground plain together?
