Author Topic: DC power supply mp710086 - problem to keep output ON by default  (Read 463 times)
Offline nudistTopic starter
  • Country: in
« on: January 23, 2022, 06:51:38 am »
I am using this new DC power supply mp710086. Since there are frequent mains power failures, at every reboot it needs a manual operation to start the output by pressing the ON button. Is there a way to to keep output ON by default after a reset of mains input supply.
Please suggest,
Thanks a lot
V
Offline Manul
  • Country: lt
Re: DC power supply mp710086 - problem to keep output ON by default
« Reply #1 on: January 23, 2022, 02:46:28 pm »
I'm not sure if it is a good idea to start messing around with the internal circuit. If it can be controlled externally by RS232, just add some arduino thingy with RS232 converter to send the command. As a bonus it would allow you to do much more, not just activating a channel. If your ever need more.
