Author Topic: Ac-DC Adaptor  (Read 951 times)
Offline alamwteTopic starter
  • Country: af
Ac-DC Adaptor
« on: February 07, 2022, 07:56:02 am »
Hello,
I have a question. Why my AC-DC adaptor that should just have 5v DC, it shows 10v AC when I measure it with AC mode of voltmeter too?
Thanks,
Offline electr_peter
  • Country: lt
Re: Ac-DC Adaptor, AC reading on DC line
« Reply #1 on: February 07, 2022, 12:15:17 pm »
What multimeter do you use? Measurement may be incorrect. Some cheap DMMs may show AC voltage (and mislead you) when simple DC battery is measured ac-readings-on-dc-supply
« Last Edit: February 07, 2022, 12:17:46 pm by electr_peter »
The following users thanked this post: alamwte
Offline BeBuLamar
Re: Ac-DC Adaptor
« Reply #2 on: February 07, 2022, 05:28:03 pm »
Does it measure 5VDC when you switch the meter to DC voltage?
The following users thanked this post: tooki, alamwte
Offline bob91343
Re: Ac-DC Adaptor
« Reply #3 on: February 07, 2022, 06:23:03 pm »
If you measure ac it will be calibrated with the assumption that the source is ac.  It's a meter issue.  Don't believe what you see.
  • Country: af
Re: Ac-DC Adaptor
« Reply #4 on: February 12, 2022, 05:36:24 am »
Yes, it measure 5v DC when I put it in DC mode!
  • Country: af
Re: Ac-DC Adaptor
« Reply #5 on: February 12, 2022, 05:37:42 am »
Yes, I have a cheap multimeter  :palm:
  • Country: af
Re: Ac-DC Adaptor
« Reply #6 on: February 12, 2022, 05:38:53 am »
Ok, I got it
thanks
