You can do all sorts of stuff with .measure. e.g:
.measure tran period10 trig V(vlc)=0 rise=1 targ V(vlc)=0 rise=11
.measure tran frequency param 1/period10
measures the time between the first and eleventh rising edge zero crossing of a signal named 'vlc' (i.e. ten whole cycles), then computes its frequency.
N.B. if you don't want the nodes you are plotting or using for .measure to 'hop' around :-// when you make a very small change to your circuit, name *EACH* and *EVERY* node you want to plot or measure.
The key to success with .measure is RTFM and experimentation with a simple test circuit!
However, especially when dealing with power dissipated, it can be helpful to low pass filter the instantaneous value of the expression one wants to plot or measure, before attempting to plot it or take measurements off it. This is quite difficult to do using waveform maths and its often more convenient to create a behavioural voltage source on the schematic to perform the calculation, then put it through a RC filter with an appropriate time constant and a named output node for convenient plotting or measurement.
