Author Topic: How to get started in asynchronus design?  (Read 650 times)
Offline asgard20032
« on: October 12, 2016, 03:04:02 am »
I want to start experimenting in the asynchronous design field, but how to get started? Is there any simulator, FPGA like device to experiment?
My ultimate goal would be to design a 4 bit or 8 bit cpu asynchronous, just for the fun of doing it and learning.
Offline rstofer
Re: How to get started in asynchronus design?
« Reply #1 on: October 12, 2016, 03:08:10 am »
You can model combinatorial logic in a CPLD or FPGA.  What you probably can't do is make sequential circuits operate asynchronously.  I would think that state machines are out of the question.  I know a fellow who tried to reinvent a CPU using asynchronous logic but he ultimately failed.  In the old days of transistor logic, gate delays were long and easier to deal with.  A lot of timing was done with wire length.
An ALU, itself, is a combinatorial block, no problems with it being asynchronous.  Registering the output is a different matter.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: October 12, 2016, 05:44:42 am »
You could download something like Xilinx ISE/Vivado or Altera Quartus and just use their simulators. You can then always shove your designs into actual FPGAs at a later time.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
