Author Topic: Hameg 604-3 test waveform  (Read 500 times)
Offline pcolbeckTopic starter
« on: August 09, 2020, 09:41:39 am »
Hi
I'm a beginner just buying my first lab equipment. I have bought a Hameg 604-3 oscilloscope on eBay that the vendor didn't know if it worked or not (inherited and they weren't a technically inclined and didn't know anything about scopes) the photos showed that the LEDs on the control panel lit up OK but there was nothing on the CRT.  As yet I have no signal generator.
So the question is does the 604-3 have the ability to generate a test waveform itself so I can check if it works?
If it doesn't it was cheap so no huge loss but it would be nice to be able to quickly determine if its a completely dud or not.
Thanks
« Last Edit: August 09, 2020, 08:24:20 pm by pcolbeck »
Offline MosherIV
Re: Hameg 604-3 test waveform
« Reply #1 on: August 09, 2020, 10:55:24 am »
Hi
Yes, most scopes have a test square wave signal to allow correct adjustment of scope probes.
On the Hameg 604-3 the test signal is just below the crt on the far left.
« Reply #2 on: August 09, 2020, 12:05:02 pm »
Smashing.
Many thanks.
« Reply #3 on: August 09, 2020, 12:16:10 pm »
A lot of scopes have minor issues which are fairly easy to correct. Check the panel controls are set up first properly and try and get a stable single channel trace out of it first. You don’t need a test signal for that.  If that fails various forum members here can probably talk you through an evaluation and/or repair.
If you’re new to this, post a picture of the entire front panel with it powered up to see what situation is.
It’s a very nice analogue scope when it’s working so worth pursuing a repair if needed.
« Last Edit: August 09, 2020, 12:19:24 pm by bd139 »
« Reply #4 on: August 09, 2020, 07:42:54 pm »
Thanks I will.
I started a degree in Electrical engineering back in the early 80s but dropped out and fell into computing and have been a network engineer for over 30 years. So I am not completely clueless on the basics of electronics but its been a very long time :) Never thought back then that it would be possible to own the kind of kit you can now for a home lab, its amazing really,
« Last Edit: August 09, 2020, 07:49:50 pm by pcolbeck »
« Reply #5 on: August 09, 2020, 07:47:14 pm »
Did exactly the same thing here :)
Haven’t had an EE job for 21 years now I think it is.
