it keeps showing that 'minus' on the top left and an "H" (only the 'dot' changes if the dial-setting is changed).
The fuse works and it was replaced to make sure anyway and it's the same on another multimeter-battery.
It broke when I went from "20" voltage setting towards OFF
while it was measuring a car battery while the alternator(car engine) was on and I wonder if it's an easy fix or a whole main chip died that costs more than the multimeter or something (it's my cheap multimeter so I have another to do tests).
