Author Topic: How to Make a Axial Fan Survive 1 Year in 99% Humidity at 25°C?  (Read 2108 times)
Offline Richard1130Topic starter
  • Country: cn
    • hdhfan
Hello everyone,
I'm currently testing the durability of EC fans in high-humidity environments and I'm looking for advice or suggestions on how to improve performance.
Here’s my setup:
Fan model: 80x80x38mm, EC 48V, Plastic body, and impeller
Protection: Shaft core sealed with waterproof potting compound
Test conditions:
Group A: 3 fans in a chamber with 99% humidity, 25°C
Group B: 3 fans in a chamber with 25% humidity, 25°C
Goal: Continuous operation for 1 year
Result: The 3 fans in the 99% humidity chamber began to fail one by one after around 200 days of operation.
I suspect moisture is still penetrating into critical parts of the motor or bearings despite the waterproof potting. Has anyone dealt with similar conditions? Any tips on structural design changes, coating methods, or material choices to improve long-term humidity resistance?
Your suggestions or any shared experience would be greatly appreciated!  :-+
https://www.hdhfan.com
« Last Edit: April 24, 2025, 02:32:17 am by Richard1130 »
Offline wraper
  • Country: lv
Re: How to Make a Axial Fan Survive 1 Year in 99% Humidity at 25°C?
« Reply #1 on: April 24, 2025, 02:38:23 am »
I'd avoid using ball bearing fans for this.
The following users thanked this post: Richard1130
  • Country: cn
    • hdhfan
« Reply #2 on: April 24, 2025, 02:46:35 am »
Indeed, upon disassembly, we found signs of rust on the ball bearing.
Offline thm_w
  • Non-expert
« Reply #3 on: April 24, 2025, 11:42:25 pm »
What do you mean by "waterproof potting compound"? Its a cured silicone? If so there will still be a gap for the rotating element, you'd need a o-ring seal or something more advanced.
But instead of doing that, why not just look at off the shelf IP55, IP65, IP66, etc. rated fans?
https://yccfan.en.made-in-china.com/product/WxyUwKAPgYka/China-Waterproof-IP66-24V-120X120X25-Cooling-Fan.html
The manufacturer might tell you what kind of tests they run, if the PCB is potted, etc.
Another option would be to use a magnetic coupling, but, thats probably only needed for actual water pumps.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4 on: April 25, 2025, 04:48:18 am »
I remember years ago when I was working as an electrician, we would source fans (Papst etc IIRC) from RS Components that were environmentally 'hardened' (I don't remember the actual nomenclature) when we replaced the cooling fans in outdoor kiosks (think things like the security beeper boxes for boom gates and the like).
They seemed to last a long time in the humid subtropical climate of Brisbane, Australia.
« Last Edit: April 27, 2025, 03:04:54 pm by TERRA Operative »
Offline amyk
« Reply #5 on: April 25, 2025, 05:15:07 am »
Pack bearings with grease.
  • Country: cn
    • hdhfan
« Reply #6 on: April 25, 2025, 08:45:12 am »
The waterproof potting compounds are materials used to encapsulate electronic components. In fact, the waterproofing is very good, but I don't know how moisture can get in. Thank you for the advice tho.
  • Country: cn
    • hdhfan
« Reply #7 on: April 25, 2025, 08:47:29 am »
Thank you for the advice. ;)
Online tooki
« Reply #8 on: April 25, 2025, 09:09:14 am »
Right. Potting compound is a type of sealant for non-moving parts. But the part that rusted is the ball bearings, which aren’t potted. (And can’t be; if you potted them they wouldn’t be able to move.)
Well clearly the waterproofing is not very good.  :-//
Why not ask a reputable fan manufacturer about fans for a very high-humidity application? This is hardly an unusual situation, all things considered. Just make sure it’s a fan manufacturer that doesn’t only specialize in PC fans. You want a company like Papst that makes fans and motors for all kinds of applications, including refrigeration, HVAC, and industrial stuff.
Offline Tina wang
  • Country: cn
    • Axial fan
« Reply #9 on: April 27, 2025, 03:36:32 am »
Your test requirements are very similar to those of one of our German customers. You can choose a more professional fan from HDHFAN.https://www.hdhfan.com/
Offline wraper
  • Country: lv
« Reply #10 on: April 27, 2025, 03:46:58 am »
At 25oC you don't even need ball bearings for long life. Sleeve bearings will last a long time at such temperature, not to say there are other longer life variants such as Sunon Vapo/Maglev, FDB bearing and similar which prevent lubricant loss and have similar or even longer lifetime than ball bearings unless operated in hot environment.
Offline CatalinaWOW
« Reply #11 on: April 27, 2025, 04:08:29 am »
While I agree that ball bearings probably aren't required in this application, many rust resistant versions of ball bearings are available.  Stainless steel, plastic and ceramics with variants in each of those major categories.  One thing that is overlooked is that rust resistance must be built into all components.  Things like retainers, shields and seals, not just the balls and races.   This will also apply to bushed bearings.  The bushing can be rust resistant, but if the shaft is not also resistant failure can come more quickly than expected.
Another thing which tends to limit life in hot humid environments is mold.  The usual approach to controlling that is sealing as you are doing, and fungicidal additives to materials.  I don't know if or how that is done these days, but suspect it involves some very cautious navigation between environmental regulations and effectiveness.
Offline Tina wang
  • Country: cn
    • Axial fan
« Reply #12 on: April 28, 2025, 01:27:46 am »
Good idea :-+
Offline BrianHG
    • LinkedIn
« Reply #13 on: April 28, 2025, 01:34:05 am »
Thick water-resistant lithium based grease.
However, only expect around 1-2years if you run the fan continuously in that 99% humidity environment.
Offline coromonadalix
« Reply #14 on: April 28, 2025, 06:01:08 am »
you have ceramic / diamond strength based bearings
Offline Coordonnée_chromatique
« Reply #15 on: April 28, 2025, 07:19:56 am »
Hello everyone,
Hello, you haven't say what failed !
 :-DD
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #16 on: April 28, 2025, 08:38:26 am »
Are you using the fans in their intended orientation? Not all fans can be used in any orientation.
Online SteveThackery
  • 50 year novice
« Reply #17 on: April 28, 2025, 10:28:13 am »
Is there something weird going on here? Advertising for HDHFAN? Or just a mistake?
« Last Edit: April 28, 2025, 03:08:37 pm by SteveThackery »
Offline CaptDon
  • Country: is
« Reply #18 on: April 28, 2025, 12:48:56 pm »
You buy a fan with a completely sealed motor which drives the fan through a magnetic coupling similar to pumps made for toxic or hazardous materials. The support bearings for the fan are also completely sealed. Look at the typical old style car air conditioning compressor which has a shaft to the outside world but contains freon internally to an idle pressure of at least 40PSI. The magnetic coupling is in common use in chemical stirrers and fish aquarium filters but is also available for fans used in explosive environments. Price you ask, about the same as a used car!
Offline amyk
« Reply #19 on: April 28, 2025, 07:37:00 pm »
If it's advertising they are doing it badly, as they are implying that their fans fail quickly and need help from others to try to fix it... :-//
  • 50 year novice
« Reply #20 on: April 28, 2025, 11:29:13 pm »
Yeah, I agree. I think @Tina wang didn’t realise the OP had https://www.hdhfan.com as his sig.
Offline alpher
« Reply #21 on: April 29, 2025, 12:17:08 am »
In my experience (beit at a little higher temperatures ~35C and humidities of 90%+) no axial fan will last more that a couple of years at best. Just use what's proper at these conditions, a proper stainless steel blower (or moisture resistant plastic) with motor being outside of airflow.
Offline jh15
« Reply #22 on: April 29, 2025, 12:21:26 am »
Only a year? another to be thrown away or subscription serviced device?
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
