Author Topic: How to make a simple voltage measurement device  (Read 734 times)
Offline houkensjtu
« on: July 29, 2015, 12:56:26 pm »
Hi there!
I want to make a simple voltage measurement device myself which can:
1. Measure a DC voltage range from 100-200V
2. Have reasonable accuracy, say error less than 0.1%
I thought a cheap multimeter may give me some idea so I tore down my multimeter, I expected that there would be an AD converter like chip, but the only thing I found is a single central chip(most likely a microcontroller) on the board.(you can find my photos in the attachment)
Here is my question:
1. What is the standard way to measure voltage in digital multimeter?
2. How should I deal with the high DC voltage (because usually microcontroller can't afford that high voltage input)
3. Is it better to use a seperate AD converter than using microcontroller's build-in AD converter?
Thank you all!
Offline Richard Crowley
  • KE7GKP
Re: How to make a simple voltage measurement device
« Reply #1 on: July 29, 2015, 01:57:11 pm »
Most lower-end DMMs have specialty chip like Intersil ICL7106. It handles everything from measurement to display-driving.
Simple voltage divider. Add protection clamps (diodes, etc.) if there is danger of over-voltage.
Does the microcontroller's built-in AD converter meet your requirements?
