If you have central heating in your house you just need to take the Earth from the nearest radiator to your workbench. It will have to be earthed.
McBryce.
That was what I was thinking of doing in the first place. I suppose, if I do that, it should not be a direct connection from my power strip ground pins to the radiator?
I need to put some large resistor in-between? Like 1MOhm, maybe even 10MOhm?
But there there has been comments here making it sound like it is a bad idea. Like, I should first make sure the radiator is connected to mains earth...but there is no mains earth/ground wiring in this house... except in the kitchen. And I need to get the thumb out and ask my landlord how things are set up in this old house... Where is mains earth wiring really located here in this house. I don't want to drag a cable out to my kitchen sink.
Maybe I could check if the kitchen sink is connected to my radiator pipes? I just need a long cable.
Some say, a large mass of copper (or other good conductor material) would do just fine as a decent ground point.
It sounds like an easy and good solution, if it really works as intended. Not only in theory I mean, but actually works very well in reality.
It's not the first time I hear about that. I think my understanding of this comes from my basic knowledge in physics that I might have read it in a physics book or got taught in school.
Wiring something out of the window down to ground from the second floor where I live just feels awkward.
I don't want to build a nice lightning rod connected into my expensive equipment.
I can measure from my floating ground in my power strip to the radiator a 113VAC, what that does that mean really?
Reminds me alot of when I got floating Vcc pins on circuit boards, and I measure 1.65V on them with reference to ground (or what is supposed to be ground).
When they're supposed to be 3.3V, but the connection is broken somewhere, it is an open circuit.
I don't have a very good understanding of what that means, why it gets that way. Why half the voltage?
Also, a little bit outside of the ESD question, but. For safety of not getting electrocuted, can I actually have good use of an RCD unit in my wall outlets for my workbench equipment, or will it only cause problems?
I installed power strips with surge protection (Also not really ESD related), but then read in the manual that they're useless in ungrounded wall outlets.
But are they useless if I have an RCD before it?
I wish I just had more time and motivation to work on these things and thoughts and stupid ideas I got a little bit more.
Maybe I could have gotten things in good order already now.
But I've got so much to do surrounding my bad health situation also. And having problems both physically and mentally.
which you can read about here if you want.
https://www.eevblog.com/forum/chat/hello-from-a-sad-and-sick-engineer/Anyway, I've gotten some really good information from everyone here! I thank you so much!
I really like the EEVBLOG forum.
I just need to sort all of this information out, because all of it feels a little bit tangled up in my head right now
And also, I am not certain at all about my radiators here, they're connected down in the basement to some heating device and pump I assume.
They're old, some pipes are rusty. Some radiators leak out water. The system needs to get a refill with water every winter. The radiators was bone-dry one winter.
What I know about my radiators in this house is they are heated by water, and are earth heated (geothermal energy),or jordvärme in swedish.
I translated that here
http://sv.bab.la/lexikon/svensk-engelsk/jordv%C3%A4rmeMaybe it would be a good idea to have an ESD mat also on the floor, but they were so expensive. I can't afford one at the moment.
Now I only got this plastic mat from IKEA so that my chair won't wear out the nice wooden floor underneath.
I'm afraid this plastic mat might actually build up some charges when I'm moving around on it :|
